Magnetic North pole shifting erratically
MadMacs
Closest Airfield: GRJ
Has liked: 9 times
Unread post by MadMacs » Fri Jan 11, 2019 3:49 pm
Don't worry about old age, it doesn't last long.
SlowApproach
Re: Magnetic North pole shifting erratically
Unread post by SlowApproach » Fri Jan 11, 2019 4:39 pm
Ai. These sensationalism-seeking journalists. "Mysteriously acting up" my arse. The mag field has been doing wobblies since time immemorial.
Been liked: 43 times
Unread post by cage » Fri Jan 11, 2019 4:50 pm
It's RT, not journalism. One level below bog roll.
Mfezi
Post Take off checks
Closest Airfield: FAKT
Unread post by Mfezi » Fri Jan 11, 2019 7:41 pm
No, it is not RT. It is based on this article from the Nature International Journal of Science, a very highly respected source:
https://www.nature.com/articles/d41586-019-00007-1
Unread post by cage » Fri Jan 11, 2019 7:47 pm
Fair enough. Ruskis get to see another day ;)
Has liked: 29 times
Been liked: 65 times
Unread post by jimdavis » Fri Jan 11, 2019 9:55 pm
I have no idea why scorn was poured upon this. I find it very interesting. If the chart is a conical, or modified, conical projection, as it appears, it would seem that the pole has moved more during the last 15 to 18 years than it did in the previous 100 years.
I wonder what that is all about. And does the geomagnetic south pole move in exact synch with the antipode of the geomagnetic north pole? Anyone know?
"So Others May Live", "PPL Manual", "Flight Tests", and "Flying in Africa" Volumes I & II. Look inside these books, and buy them at: www.jimdavis.co.za.
nrm
Unread post by nrm » Sat Jan 12, 2019 6:33 am
Is the earth wobbling off its axis, as was written in the book "Down to a sunless sea".
Magnificent story.
Neville Matthews
MadMacs
Has liked: 9 times
Unread post by MadMacs » Sat Jan 12, 2019 6:44 am
Jim, you are always the voice of reason, and Cage is getting grumpier by the day. :) You always pose interesting questions which stimulate the mind and is how topics on this forum should be handled, not with sarcasm and is why I like posting topics.
In response to your question, I decided to look around for an answer and came up with this link:
https://www.npr.org/2011/01/14/1329340 ... orth-pole
SaraLima
Closest Airfield: FASH and Morningstar
Unread post by SaraLima » Sat Jan 12, 2019 8:49 am
Magnificent story.
Agreed... it was a brilliant and tense read. :D
There are three simple rules for making a perfect landing. Unfortunately, no one knows what they are.
I was flying in uniform when you were still in liquid form :wink:
JCA
Closest Airfield: Krugersdorp
Unread post by JCA » Sat Jan 12, 2019 8:51 am
It's the bloody Boy Scouts again, I tell you........
Has liked: 29 times
Unread post by jimdavis » Sat Jan 12, 2019 9:21 am
Thanks MM - that link is absolutely fascinating. I find it particularly interesting that that the magnetic N an S poles do not move in synch.
SlowApproach
Unread post by SlowApproach » Sat Jan 12, 2019 10:05 am
The problem I have with the reporting (even from reputable sources) is that the "mystery" and not-so-quiet panic is based on less than only 200 years of record-keeping. The data that assumptions are thus based on is infinitesimally small compared to the age of the Earth. A classic issue when modelling something with so little data for such a relatively insignificant period of time: If the model doesn't fit the actual, typically all hell breaks loose. For all we know it is just part of the Earth's totally natural cycle, i.e. it has happened before, many times, and will happen again. And Again.
HJK 414
Closest Airfield: EHTW
Unread post by HJK 414 » Sat Jan 12, 2019 10:11 am
Magnificent story.
Agree
Great book - and I was really sad at the end.
JK
HJK 414
Unread post by HJK 414 » Sat Jan 12, 2019 10:16 am
Slow ......
"Liquid molten metal shifting under the poles ...." / measured as a magnetic reading shifting towards Siberia (under the Ice cap)
Is it also causing a temperature change in the ice cap in places ??
Are we seeing a possible cause of the "global warming melting the ice cap" ??
JK
SlowApproach
Unread post by SlowApproach » Sat Jan 12, 2019 10:24 am
JK, feasible indeed, I would say.
