Piper PA-30B -- engines
KZNChris
Unread post by KZNChris » Mon Mar 11, 2019 12:49 pm
More reading .......
According to Wikipedia this aircraft ( Turbo Twin Comanche ) had an Lycoming IO-320-C1A that was turbo-normalised by RayJay
NOW
Why are kit builders ( experimental ) not looking at this engine as a build option ? ( > 200HP )
A well regarded commercially operated engine with Fuel Injected Turbo Normalised AND ALL the work done by the factory.
A better option than a "RATEX" or a Titan or a converted automotive engine
What do the aviation engine gurus think ?
Multirotordronepilot
Closest Airfield: Wintervogel
Been liked: 20 times
Re: Piper PA-30B -- engines
Unread post by Multirotordronepilot » Mon Mar 11, 2019 12:59 pm
The only requirement for power in that range within the NTCA bracket are airframes which could not fly with even a Rotax 915. No Rotax comes near 160hp. What I'm saying is compare like for like
Commercial pilot,Instructor,Responsible Person Aircraft
Grease monkeyVLOS/EVLOS/BVLOS operator
TopRC HawkerHunter
JetLegend ViperJet
SpiderJets F16
BVM F80 ShootingStar
WorldModels 1/3Cub
ZS-VVR
J3 Piper Cub replica under construction ZU-XXX
Unread post by Multirotordronepilot » Mon Mar 11, 2019 1:04 pm
At a second glance I see that the 915 is kind of close. What does the weight comparison look like
TopRC HawkerHunter
JetLegend ViperJet
SpiderJets F16
WorldModels 1/3Cub
ZS-VVR
KZNChris
Unread post by KZNChris » Mon Mar 11, 2019 1:15 pm
http://www.supercub.org/forum/showthrea ... ally-weigh
From the Type Certificate data sheets
O-320- Weight (dry) and ignition, dual. By Models
Weight Lb.
-A1A, -A1B, -A2A-A2B, -A3A, -A3B ---- 244lbs
-A2D ---- 249lbs
-A2C, -A3C ---- 243lbs
-B1A, -B1B, -B2A ---- 250lbs
-B2B, -B3A, -B3B ---- 250lbs
-B2C, -B3C ---- 249lbs
-B2D ---- 283lbs
-B2E ---- 250lbs
-C1A, -C1B, -C2A ---- 250lbs
-C2B, -C3A, -C3B ---- 250lbs
-C2C, -C3C ---- 249lbs
-D1A, -D2A ---- 255lbs
-D1B, -D2B ---- 254lbs
-D1C, -D2C ---- 256lbs
-D1D ---- 253lbs
-D1F, -D2F ---- 255lbs
-D2G ---- 251lbs
-E1A, -E2A ---- 244lbs
-E1B, -E2B ---- 243lbs
-E1C, -E2C ---- 245lbs
-E1F, -E2F ---- 248lbs
-E2D ---- 249 lbs
-E2G ---- 249lbs
-E2H ---- 252lbs
-E3D ---- 249lbs
-E3H ---- 252lbs
-E1J ---- 245lbs
-D2H ---- 251lbs
-D2J ---- 255lbs
-D3G ---- 251lbs
-H1AD ---- 253lbs
-H2AD ---- 253lbs
-H3AD ---- 253lbs
-H1BD ---- 253lbs
-H2BD ---- 253lbs
-H3BD ---- 253lbs
ROTAX 915 IS / ISC
https://www.flyrotax.com/produkte/detai ... s-isc.html
Engine with gearbox, turbocharger, intercooler, cooling air baffle, wiring harness, sensors, flange with overboost valve, air hoses, clamps, magneto valve block with hoses, ECU, fusebox with regulators, oil tank, exhaust system
Without fuel pumps assembly, radiator and oil cooler
84.6 KG 186.4 LBS
There you have it
Suitable for MANY Kit Planes
KZNChris
Unread post by KZNChris » Mon Mar 11, 2019 3:08 pm
Here is RayJay Turbo's
https://rajay.aero/
Here are the STC's ( including the IO 320 C1A Twin Comanche )
https://rajay.aero/pages/list-of-stcs
As our American friends would say -- just get one from the junk yard .... :)
KZNChris
Unread post by KZNChris » Mon Mar 11, 2019 4:11 pm
This is what it looks like ( off a twin Turbo Comanche )
See attachment
From here
https://www.comancheflyers.com/
Can be had from Barnstormers from US$ 6000.0o
