Nampo 2019
Marck
Engine Cranking
Closest Airfield: FAHG
Nampo 2019
Unread post by Marck » Wed Mar 13, 2019 10:29 pm
Hi Fellow Aviators
I am thinking of flying in for Nampo this year. Has anyone flown in to Nampo? I have a question or 2
What is the runway like?
Joining amd Landing procedures?
Is there temp atc for the duration and finaly frequency
Thanks
Looking for AC.
If you push the stick forward, the houses get bigger. If you pull the stick back, they get smaller. That is, unless you keep pulling the stick all the way back, then they get bigger again
Alanza
Closest Airfield: Wonderboom
Re: Nampo 2019
Unread post by Alanza » Thu Mar 14, 2019 8:08 pm
Gras strip with few holes here and there. Depends on type of plane. Not bad. Usually ATC but can be extremely busy. Great to fly there.
Marck
Engine Cranking
Re: Nampo 2019
Unread post by Marck » Mon Mar 18, 2019 1:48 pm
Thanks for the info. How do they handle traffic? Normally one would call 10nm out. Do they follow this practice?
Looking for AC.
Kilroy
Forgot to remove the chocks!
Re: Nampo 2019
Unread post by Kilroy » Mon Mar 18, 2019 7:06 pm
Kilroy was here
pietmeyer
Re: Nampo 2019
Unread post by pietmeyer » Mon Apr 01, 2019 2:53 pm
I see all the info etc on their website but would like to know if the airfield will be in better condition as last year? Guess for big planes not too bad but a bit worried about my Jabiru. Think it was last year one had a prop strike due to the "gras polle"
I think I will wait for later in the week after some guys landed there and can give good feedback
ZU-DUU Jabi J400 (FAWB)
C Africa
Re: Nampo 2019
Unread post by C Africa » Mon Apr 01, 2019 5:41 pm
It is clear that the information on this site was not prepared by anyone with aviation knowledge.
They don't even mention runway direction :shock:
C
SJ@Farmacres
Closest Airfield: FAKD
Re: Nampo 2019
Unread post by SJ@Farmacres » Mon Apr 01, 2019 8:36 pm
We usually fly in from the Saturday before, will post info on condition here once we’ve seen. Runway itself is actually usually not so bad, more the parking area that’s a bit rough. The biggest issue is meerkat holes that get filled up before the show, but not compacted properly, if I’m not mistaken this is what happened with the propstrike, cloee to the run up pad...
Hanno
Hee Hee I'm Flying
Re: Nampo 2019
Unread post by Hanno » Thu Apr 11, 2019 8:41 pm
Anyone flying to Nampo this year from either Rand or Lanseria that have a spare seat available? Will appreciate if I can go with as I never been there before. Please let me know.Will pay pilot's entrance and lunch. :D
Hanno
Previously Venus...
Taildraggerdriver
Hot start of aircraft
Closest Airfield: faps
Re: Nampo 2019
Unread post by Taildraggerdriver » Sat Apr 13, 2019 9:23 pm
Hi Fellow Aviators
Thanks
It’s great fun
ATC is good
No fuel
Enough parking
Strip is fine
Runway is sort of east west
Check it out on google
You won’t be sorry
C210
Cirrus sailplane
Pink Panther
Closest Airfield: FAVG DTTA HLLM
Re: Nampo 2019
Unread post by Pink Panther » Wed May 08, 2019 8:03 pm
Hi All.
wanting to fly into Nampo in the King Air. Who can we get hold of to find out More on airfield conditions indemnity forms etc etc. . Or is Bothaville a better bet?
Regards PP.
ZS-UDO Ercoupe C "UDO"
ZU-CIS Starduster Too " Dusty"
Tiger Moth build. Zlin 226 Restoration.
And others waiting turn...
Pete
Has liked: 10 times
Re: Nampo 2019
Unread post by Pete » Wed May 08, 2019 8:10 pm
I see Helivate is offering helicopter charters to Nampo.. should be fun! :D
https://www.helivate.com/so/fcMfJ3DBT?c ... 2315#/main
Pink Panther
Re: Nampo 2019
Unread post by Pink Panther » Thu May 09, 2019 8:14 am
Are there any numbers I can try to get some more info?
sabrown
Closest Airfield: Upington
Re: Nampo 2019
Unread post by sabrown » Thu May 09, 2019 8:31 am
Flying in on Monday morning with a Jab 4, will post something after landing. I'm taking off the spat's again like last year because if strip is in same condition it will be damaged.
Aerofly
Re: Nampo 2019
Unread post by Aerofly » Fri May 10, 2019 12:09 pm
If anyone has a spare seat available to Nampo from FAWB Wonderboom, i would like to go
Thank you
Please PM
1Jn 4:10 This is the kind of love we are talking about--not that we once upon a time loved God, but that he loved us and sent his Son as a sacrifice to clear away our sins and the damage they've done to our relationship with God. (The Message)
Col
Closest Airfield: Oribi
Re: Nampo 2019
Unread post by Col » Sat May 11, 2019 8:21 am
I flew in yesterday in an Explorer, with 21” Tyres, the runway is bumpy but didn’t see any holes. The grass is cut. A few holes at the run up pad have been filled in with sand. No windsocks. Any aircraft with marginal prop clearance should be wary.
