Supplier of small pieces/off-cut aluminium in Pretoria?
heinrich
Closest Airfield: EGSX
Has liked: 28 times
Re: Supplier of small pieces/off-cut aluminium in Pretoria?
Unread post by heinrich » Tue Nov 29, 2011 10:36 am
Dankie Justin, will give them a call.
noelotten
Been liked: 10 times
Unread post by noelotten » Tue Nov 29, 2011 4:52 pm
heinrich wrote: I am curious to know if you guys know where to get ali extrusions? Spoke to alclad and they only sell ali sheets. They reckon if you want 2024-T4 Ali bar or 6061-T6 angle you need to "bring it in" yourself? :cry:
Does anyone sell it in SA?
It depends on what you are looking for!
Aluminium City, (outlets for HULETT'S), stock a wide range of standard sections and they will source special if you need them.
Alu-Stock and Conways are outlets for WISPECO, and will do the same.
Go to the Hulett's and Wispeco websites and download their standard catalogues! If you want close tolerance extrusions, Hullet's will be your best bet!
Noel
heinrich
Has liked: 28 times
Unread post by heinrich » Wed Nov 30, 2011 8:42 am
Thanks Noel, noted. I am interested in various extrusions like 3/4x3/4 x 125 6061-T6 angle, 3/4 x3/4 x 062 6061-T6 angle etc. and also flat 2024 T4 bar of various sizes.
H
wingnutzster
Closest Airfield: Sommerveld
Been liked: 16 times
Unread post by wingnutzster » Wed Nov 30, 2011 9:13 am
I highly recommend that this thread be moved to the Aircraft Builder's section, the kinds of traffic through there is they type you want to answer these questions. :)
Shay
Unread post by Shay » Mon Feb 11, 2019 4:10 pm
Having worked in the metal industry for a good few years I can recommend two places that sell aluminium offcuts. Neither are in Pretoria but are worth the travel if you cant find any there. These recommendations are for offcuts, not aluminium in general.
Metals Centre in Selby sell from "scratch patch" boxes of offcuts (aluminium on their website redirects to this domain so they must own it) - http://www.laser-cutting-online.com/alu ... sions.html
Aluminium Trading in Edenvale also stock offcuts and a wider range including 6xxx series extrusions you listed - https://www.aluminiumtrading.co.za/alum ... xtrusions/
Give them both a call, I do recommend Aluminium Trading however, as you will get better service.
Hope this helps.
Regards,
Shay
