Removing scratches from perspex windscreens
LeRoux
Closest Airfield: AFB Overberg
Re: Removing scratches from perspex windscreens
Unread post by LeRoux » Thu Aug 31, 2017 10:16 am
Here is the latest contact details if someone needs Vuplex
Craig Ralphs
VuPlex Distributor South Africa
Mobile: +27 83 635 5295
eMail: admin@vuplexsa.co.za
Russell Phillips
Post Take off checks
Closest Airfield: FAPE
Been liked: 24 times
Unread post by Russell Phillips » Thu Aug 31, 2017 12:16 pm
The trade names for the different materials seem to differ between countries and cause some confusion. In SA we only really have two types of canopy/windscreen material around. In SA they go by the names:
1) Perspex (cast acrylic) - typical thermo formed canopy/bubble
2) Polycarbonate - typical flat wrapped windscreen
The first is very forgiving and you can polish out small scratches, over spray etc.
The second is nasty stuff which I find you can do very little with in terms of repair. It also "crazes" with time in high stress bend areas and around bolts etc. Have had very little luck removing scratches etc too. It is however the material mostly used for cold bent, thin flat wrap windscreens on many of the LSA's (Kitfox, Pipistrel etc). Typically needs replacement every few years (in my experience).
Horace Blok
Closest Airfield: FAMO
Has liked: 199 times
Been liked: 53 times
Unread post by Horace Blok » Sun Sep 10, 2017 11:22 am
I received my VUPLEX from the Cape Town distributor who went out of his way to get the product to my daughter in CT. We had rendezvous hassles but he so kindly assisted and now its off to the bike and aircraft to get rid of those pesky scratches. Looking at the video - I look forward to its many benefits - and it looks darn easy.
The CT distributor is an OLD Avcommer Paul van Tellingen. His email is cape@vuplexsa.co.za
Mobile - 083 292 3265
Thanks Craig for your help too. Invoice received.
Hartog
Can1
Closest Airfield: Pietermaritzburg
Has liked: 44 times
Been liked: 15 times
Unread post by Can1 » Sun Sep 10, 2017 7:18 pm
You are most welcome Horace and thank you for your business.
Safe Flying
Kindest regards
Craig Ralphs
http://www.vuplexsa.co.za
Why be yourself when you can be someone really worthwhile - Richard Bandler
I'm not a complete idiot.........Some parts are still missing :wink:
Induna
Closest Airfield: FASD
Has liked: 149 times
Been liked: 166 times
Unread post by Induna » Sun Sep 10, 2017 7:37 pm
This seems like an interesting topic.
I polished my canopy with a slow electric buff and brasso.(very time consuming) All the scratches are gone but i can see some circular patterns on the canopy in bright sunlight.
Will Vuplex remove it and makes it flawless?
Jacques
Jacques van der Westhuizen
ZS-WSW | Sonerai 2L
ZU-FBA | Sonex Aircraft Waiex
Horace Blok
Unread post by Horace Blok » Mon Sep 11, 2017 12:03 pm
Jacque - I'm very happy with the result. Obviously, the deep etched chips from stones on the bike screen is too much for it to remove but yes, I'm happy. I still need to go out to the airfield and do the aircraft.
Hartog
Mr B
Steep Turn Left
Unread post by Mr B » Tue Sep 12, 2017 2:46 pm
I see its a new product just arrived at Wings & things at FALA
Martin Bevelander
ZS VAL C177A
