GK 1 ZU BLJ is flying
Neville Ferreira
Been liked: 167 times
Re: GK 1 ZU BLJ is flying
Unread post by Neville Ferreira » Wed Feb 17, 2021 4:58 am
Flight Test done.
These users liked the author Neville Ferreira for the post:
Christopher
Neville Ferreira
Unread post by Neville Ferreira » Sat Feb 20, 2021 5:26 pm
4 flight today:
FAKT-FABS
FABS-FAKT
FAKT-FASI
FASI-FAKT
Total flight time 1:34 and 22L used. Average speed over 4 flight 178mph. Max speed on gps 217mph.
Has liked: 646 times
Been liked: 497 times
Unread post by richard C » Sat Feb 20, 2021 6:16 pm
There is something very 'Mew Gull' about this aircraft in the coolest possible way.
Grant all equity and dignity
Neville Ferreira
Unread post by Neville Ferreira » Sat Feb 27, 2021 2:51 am
Closest Airfield: FAHT
Has liked: 146 times
Been liked: 477 times
Unread post by GL » Sat Feb 27, 2021 6:58 am
Lovely!
Full report out tomorrow in March SA Flyer
These users liked the author GL for the post:
Bugs
Neville Ferreira
Unread post by Neville Ferreira » Sun Apr 11, 2021 5:43 am
218mph achieved all below 1500' above the runway.
Last edited by Neville Ferreira on Tue Apr 13, 2021 9:45 am, edited 3 times in total.
Closest Airfield: FAPX
Has liked: 195 times
Been liked: 556 times
Unread post by Chalkie » Sun Apr 11, 2021 12:09 pm
Hi Neville, just a thought. In an RV-4 / -6, the only flight control that is not balanced is the rudder and this is the first control to flutter as has been demonstrated by that dentist fellow in the USA who has a super fast RV-4.
So question: are both the elevators and the rudder not balanced in the GK 1, or do the elevators have an internal balance weight?
These users liked the author Chalkie for the post:
AEH
Neville Ferreira
Unread post by Neville Ferreira » Sun Apr 11, 2021 2:06 pm
Chalkie, this is a question to be answered by Russel Phillips. I just fly the GK, and keep below vne 230 mph. From memory but please do not quote me, stick forward = houses get bigger.
These users liked the author Neville Ferreira for the post (total 2):
Mrb13676AEH
Jaco-P
Unread post by Jaco-P » Tue Apr 13, 2021 2:46 pm
Nice pic (the first one) :wink:
And yes - Its my pic. :)
It makes a fantastic noise that I can tell you!
Neville Ferreira
Unread post by Neville Ferreira » Tue Apr 13, 2021 3:26 pm
Looking over the nose on landing is not an option.
Neville Ferreira
Unread post by Neville Ferreira » Sun Apr 25, 2021 6:02 pm
[media] [/media]
wallaby
Taxiing
Closest Airfield: FASD
Unread post by wallaby » Mon Apr 26, 2021 11:43 am
Jislaaik Neville, daai aerie klink bitter mooi!
Manie Rossouw
Raven ZU-IGP
Induna
Has liked: 155 times
Been liked: 169 times
Unread post by Induna » Mon Apr 26, 2021 12:01 pm
En hy lyk ook mooi!
Jacques van der Westhuizen
ZS-WSW | Sonerai 2L
ZU-FBA | Sonex Aircraft Waiex
Johan Swakopmund
Closest Airfield: Swakopmund
Has liked: 245 times
Been liked: 205 times
Unread post by Johan Swakopmund » Mon Apr 26, 2021 12:32 pm
Neville
Het jy al voorheen die enjin en prop spesifikasies geplaas.
Byvoorbeeld wat is die aan die enjin gedoen / petrol inpsuiting , is dit elektroniese onsteking of het dit n Magneto
een of twee plugs per silinder.
Wat is die reduction na die prop en wat se prop het jy op. Wat is die reduction ratio.
Hierdie lyk na n goed getoetste kombinasie. Daar is baie prop enjin kombinasies maar die goed
word nie weekliks of genoeg gevlieg om regte werkverigting en duursaamheid te kan bevestig nie.
Hierdie is die eerste nie komersiele ( Rotax of Jabiru ) kombinasie wat ek ken wat nou al deur en deur
getoets is en betroubare inligting vanaf verkry kan word.
As jy inligting het plaas asseblief
groete
Johan
NAMIBIA FLYING COUNTRY
Neville Ferreira
Unread post by Neville Ferreira » Mon Apr 26, 2021 5:53 pm
Neville
groete
Johan
Johan
Single plug ignition. 2 ignition systems, one is the Honda CB 750 bike ignition and second is Spitronics.
I use the old for start and backup and after start switch to electronic ignition. Both share the same coil pack. As there is no starter I have to prop swing hence the reason why the electronic ignition cannot be used for start as it requires 360 deg to know where it is. On the cam pulley is a sensor with 36-1 tooth gear.
Zenith CD175 carburettor instead of fuel ignition for space saving.
The belt drive is a 100mm wide reduction drive with 2.29:1 ratio.
At the moment I am investigating a prop upgrade as the original prop is for sub 100 knot aircraft and almost 30 years old.
AX sport constant speed prop most likely to be the choice with a 20mph expected gain In cruise speed.
Johan Swakopmund
