Sakkie Halgreen’s – ZS-UKU restoration project
Kend Rand designed his KR-1 in 1972, he also pioneered a state-of-the-art foam-and-fiberglass composite construction method which has now become standard in homebuilt, commercial, and military aircraft.
FlyKR
HASSELL checks
Re: Sakkie Halgreen’s – ZS-UKU restoration project
Unread post by FlyKR » Sun Dec 02, 2012 8:03 pm
Howzit Rudi. Turbo is an Aireresearch M10 from the Nissan EXA....according to Google :D
Only real pilots can fly KR's
Rudix
Unread post by Rudix » Sun Dec 02, 2012 8:06 pm
FlyKR wrote:Howzit Rudi. Turbo is an Aireresearch M10 from the Nissan EXA....according to Google :D
Hi Carlton!
Thanks, did not look familiar!
giarc64
Unread post by giarc64 » Sun Dec 02, 2012 9:24 pm
Hey Bud
Great work, can't wait to see her fly. will be a treat to have a few KR's flying in formo. WPX will be there soon
cheers
Craig
ZU-CYB (Cubby No 1)
ZS-WPX (KR2)
FlyKR
HASSELL checks
Unread post by FlyKR » Fri Dec 07, 2012 2:16 pm
Busy working on the cowling, I"m seeing da light at the end of the tunnel... :)
FlyKR
HASSELL checks
Unread post by FlyKR » Fri Dec 07, 2012 2:19 pm
Another one
FlyKR
HASSELL checks
Unread post by FlyKR » Fri Dec 07, 2012 9:10 pm
Today I did some more work on the cowl, there was 3mm gap (photo above) between the firewall and bottom part of the cowl that needed filling.
I sorted this out by glassing on a backing strip of cloth onto the inside of the cowl, after this cured over night I applied filler and sanded it flush with the outside cowl surface. I then sanded down the cowling edge again to fit…..problem solved :D
FlyKR
HASSELL checks
Unread post by FlyKR » Fri Dec 07, 2012 9:16 pm
While I was busy grafting on the cowl, I heard the drone of radial engines and when I looked skywards I was blessed with this wonderful sight….. :D :D
giarc64
Unread post by giarc64 » Sat Dec 08, 2012 12:06 am
hey Carlt
these type of work brings back lots of memories. Had to do the same on my cowl many times , inorder to get the gaps sorted. looking good my man
ZU-CYB (Cubby No 1)
ZS-WPX (KR2)
StellarGuy
Unread post by StellarGuy » Tue Feb 26, 2013 11:16 pm
Hi
Looking at the pictures of UKU brings back fond memories for me. I flew in her with Sakkie around 1984 at Lanseria. That was the days when the KR2 kit sold for R12500.
She is a very special KR2 and to be honest, I have never seen another example of a KR that was so striking in looks. Sakkie loved her with a passion and he started the building process in their livig room on the small holding close to Lanseria. Was quite an experience being on finals with some Beech C90's and other twins also in the que. Sakkie took a short cut and manouvered us right in between the other planes and somehow the other pilots just let him do it, I guess they all had some affection (and repect) for this fast little bullet. I remember how we taxied thru right under a wingtip of a bigger plane. Look well after her, she deserves it.
FlyKR
HASSELL checks
Unread post by FlyKR » Mon Mar 04, 2013 11:54 pm
Just a short update on this project, I have moved UKU to the airfield and have fitted the wings, connected all the control cables and will begin engine testing in the nest couple of days. I must say shes looking great in her new colors and i can't wait to get her into the sky again.. :D
FLYBOY OBD
Closest Airfield: Heidelberg
Unread post by FLYBOY OBD » Tue Mar 05, 2013 9:14 am
FlyKR wrote:Just a short update on this project, I have moved UKU to the airfield and have fitted the wings, connected all the control cables and will begin engine testing in the nest couple of days. I must say shes looking great in her new colors and i can't wait to get her into the sky again.. :D
Good luck with taking to the sky!The work is a great art!You know your stuff! =D> =D> Send me your number through Debbies bbm to my wife!Blue skies.Johan Henning
FLY SAFE!!FLYBOY OBD
GerhardRossouw
Power off stall
Closest Airfield: Fisantekraal
Unread post by GerhardRossouw » Tue Mar 05, 2013 8:27 pm
Great stuff Carlton! Show us the photo`s........please. Exciting times.
KR2
ZS-UIR
FlyKR
HASSELL checks
Unread post by FlyKR » Fri Mar 08, 2013 9:22 pm
Today I fitted the new seat belts, did final installation of the seats, got the fuel gauge working and fitted the spinner. Still on the to do list is finish the cowling, fit the canopy and finish the wing gap seals then it's W&B after which I can start taxi tests. :D cool..we almost there 8)
Sorry lads I cannot take pics laptop took a dive and uploading pics from iPad don't work :roll:
FlyKR
HASSELL checks
Unread post by FlyKR » Sat Mar 16, 2013 7:49 pm
Check out the latest photos of this project now nearing completion. All I need to do now is paint the cowls, W+B and taxi tests then she’s good to go….sweet :D
GerhardRossouw
Power off stall
Unread post by GerhardRossouw » Sat Mar 16, 2013 10:53 pm
It`s looking very neat Carlton! =D>
KR2
ZS-UIR
Return to “KR”
