Raven Electric Trim Question
The Raven type of aircraft.
Hooligan
Fuelling up
Closest Airfield: hoedspruit
Unread post by Hooligan » Thu Mar 28, 2013 12:41 pm
I would like to buy an elevator electric trim kit for our Raven, im looking at the RAC (Ray Allen) kits.
I wont be installing it myself, ill get it installed by an AP who knows what they are doing.
My problem is im confused as to which size kit I should order. I see there are 3 sizes/travel kits available, could any of you please advise which size I should order?
They are:
- T2-7A Trim System which has .7" (17mm) travel, 10 sec.
- T2-10A Trim System which has 1.0" (26mm) travel, 16 sec.
- T3-12A Trim System which has 1.2" (31 mm) travel ,19 sec.
See here for details http://www.rayallencompany.com/products ... stems.html
Airscrewed
Re: Raven Electric Trim Question
Unread post by Airscrewed » Tue Apr 02, 2013 7:20 pm
The smallest one is fine - I use two of them, one for elavator and one for aileron trims.
Hooligan
Fuelling up
Unread post by Hooligan » Mon Apr 15, 2013 1:09 pm
Airscrewed wrote:The smallest one is fine - I use two of them, one for elavator and one for aileron trims.
Thanks for the info!
Return to “Ravens”
