Disk brakes?
The Raven type of aircraft.
Has liked: 40 times
Been liked: 344 times
Disk brakes?
Unread post by heisan » Mon Mar 02, 2015 10:26 pm
Does anybody know which specific makes/models of disk brakes can be made to fit inside those forks?
Thanks,
Justin
Induna
Closest Airfield: FASD
Has liked: 104 times
Been liked: 127 times
Re: Disk brakes?
Unread post by Induna » Tue Mar 03, 2015 1:22 pm
Justin, as jy die oorspronklike Azusa rims het, gaan kyk op Aero Conversions se website. Hulle maak nou n drop in replacement vir daardie wiele.. Baie goedkoper as om al die wiele te ruil..
Daar is n agent vir hul in RSA ook.
Jacques
Jacques van der Westhuizen
ZS-WSW | Sonerai 2L
Has liked: 40 times
Re: Disk brakes?
Unread post by heisan » Tue Mar 03, 2015 1:25 pm
Induna wrote:Justin, as jy die oorspronklike Azusa rims het, gaan kyk op Aero Conversions se website. Hulle maak nou n drop in replacement vir daardie wiele.. Baie goedkoper as om al die wiele te ruil..
Jacques
Thanks - been eyeballing those, but I can't find anyone who has actually installed them yet. Seems there may be issues with it pushing the bearings in if you brake too hard...
Induna
Re: Disk brakes?
Unread post by Induna » Tue Mar 03, 2015 1:30 pm
Ek weet nie of dit so groot probleem gaan wees nie. die rims het n skouer waar die bearing sruk en die krag wat die calipers uitoefen is nie verskriklik baie ivm kar brieke bv nie..
Alternatief is om Cleavlnd wiele te installeer, maar gaan jou n arm en n been kos. Johann Froneman het n stel op sy Raven gesit, maar moes bussies sny om als te spasieer..
J
ZS-WSW | Sonerai 2L
Has liked: 40 times
Re: Disk brakes?
Unread post by heisan » Tue Mar 03, 2015 1:33 pm
Induna wrote:Ek weet nie of dit so groot probleem gaan wees nie. die rims het n skouer waar die bearing sruk en die krag wat die calipers uitoefen is nie verskriklik baie ivm kar brieke bv nie..
J
Yeah. The aeroconversion brakes press from one side only - all the braking force pushes the wheel to the side. 'Normal' brakes squeeze the disk from either side - so no force on the wheel.
I have another set of callipers, but cannot fit them inside the fork. Hoping to see what other people have had success with.
Return to “Ravens”
