Justin's Raven Build (now engine change)
The Raven type of aircraft.
Has liked: 43 times
Been liked: 422 times
Re: Justin's Raven Build (now engine change)
Unread post by heisan » Sun Feb 01, 2015 7:20 pm
PS - This plane is an absolute ball to fly. The stubby wings absorb the bumps nicely. Controls are responsive but still have good feel. And it is obscenely powerful.
Jean Crous
Closest Airfield: FASX
Has liked: 492 times
Been liked: 212 times
Unread post by Jean Crous » Sun Feb 01, 2015 10:15 pm
Justin as the saying goes, " If it fits under the cowls , then it is too small 1 " :twisted: :twisted: :mrgreen:
Jean.
Cubby Aircraft Factory
Cell : 072 6716 240
SACAA Approved Person 402
Has liked: 43 times
Unread post by heisan » Wed Dec 09, 2015 10:45 pm
Heh... Haven't updated this thread for a while. Replaced the XCOM radio with a MGL v6, and the radio problems were at east temporarily solved. Net result is this:
Has liked: 43 times
Unread post by heisan » Wed Dec 09, 2015 10:50 pm
Since then, I have been getting my *rse kicked in some serious turbulence these past few weekends. These little wings certainly ride the bumps better than most, but perhaps flying mid-afternoon in 36C temps is not the best idea... At least I know it can take some punishment ;) .
New radio issue cropped up on Saturday - picking up a lot of ignition noise on the radio. Other people can hear me fine, but I can barely hear them. Need to get this sorted out ASAP if I want to fly away on holiday this year...
Induna
Closest Airfield: FASD
Has liked: 136 times
Been liked: 154 times
Unread post by Induna » Wed Dec 09, 2015 10:56 pm
Ek het ook n MGL V6 radio in my Raven en ek moet se, hy werk pragtig en het geen geraas nie...
Jacques
Jacques van der Westhuizen
ZS-WSW | Sonerai 2L
ZU-FBA | Sonex Aircraft Waiex
Has liked: 43 times
Unread post by heisan » Thu Dec 10, 2015 11:06 am
Induna wrote:Ek het ook n MGL V6 radio in my Raven en ek moet se, hy werk pragtig en het geen geraas nie...
Jacques
Comms were excellent until this last flight. I think it is one of the Jabiru bug-bears coming to bite me (rotor/dizzy cap arcing, or something similar). Will go over the entire ignition system on Saturday morning.
johannvanniekerk
Tripped over wheel chock
Unread post by johannvanniekerk » Sat Jan 16, 2016 7:28 am
Hi Justin
Het jy jou V6 uitgesorteer? Myne werk goed, behalwe een pax wat soms kla oor bietjie lawaai as ek transmit
Johann
Has liked: 43 times
Unread post by heisan » Sat Jan 16, 2016 10:01 am
johannvanniekerk wrote:Hi Justin
Johann
Largely fixed. Replaced the antenna cable with mil-spec, and most of the ignition noise went away. Still some, but only really noticable 100nm+ from station.
RSH2
Closest Airfield: Jack Taylor
Unread post by RSH2 » Fri Dec 02, 2016 9:27 am
Morning morning Justin, how is the flying going ? :)
Has liked: 43 times
Unread post by heisan » Fri Dec 02, 2016 10:55 am
RSH2 wrote:Morning morning Justin, how is the flying going ? :)
Been a slow month. Found some cracks on the front gear top bracket, so been doing some metal work. Inspection tomorrow, then paperwork, then I can fly again.
130 hours so far, and this is the first real issue.
johannvanniekerk
Unread post by johannvanniekerk » Tue Feb 21, 2017 6:45 pm
Hi Justin
Het jy fotos wat die probleem wys?
Has liked: 43 times
Unread post by heisan » Tue Feb 21, 2017 10:30 pm
Could have sworn I took a photo before I started work, but apparently not...
This is after I cut off the cracked material. The crack ran horizontally just below the corner. The material was so badly work hardened, it shattered when I cut it! Apparently cracks in this area are quite common.
Return to “Ravens”
