Cessna 172 Engines.
gerhardsteenkamp
Cessna 172 Engines.
Unread post by gerhardsteenkamp » Fri Jan 30, 2015 7:29 pm
Evening all,
Was hoping someone could shed light on a subject for me? What are the implications if you want to install a different engine in an aircraft that is also listed on the Aircrafts Type Data Sheet, but the engine wanting to be installed is not on the TDS for the specific model aircraft that you have. What if the engine is on the same Type Data Sheet from the Manufacturer(Engine manufacturer).
Any replies appreciated.
Gerhard Steenkamp
The sky is not the limit, it's just another playground
CPL(A) ME/IR, Tow Rating, Tailwheel- and Turbine Endorsed
C150, C172, PA28(140-181), TC-06,TC-07, C82R, C182, C72R, DV20, SR20, BE55, T210, P32T, C42, PA32, C206, SF25, JAB4, JAB2, JAB1, C208
Closest Airfield: Ermelo
Has liked: 75 times
Been liked: 565 times
Re: Cessna 172 Engines.
Unread post by Whirly » Sat Jan 31, 2015 7:35 am
Find out if there is a STC for that engine to be used in the C172, buy it and Bob is your uncle! :D
gerhardsteenkamp
Unread post by gerhardsteenkamp » Thu Feb 05, 2015 10:46 am
Whirly,
Issue is I can't find an STC for the engine I want... :(
GCS
Has liked: 75 times
Unread post by Whirly » Thu Feb 05, 2015 10:52 am
gerhardsteenkamp wrote:Whirly,
GCS
Which engine would that be then? :?
gerhardsteenkamp
Unread post by gerhardsteenkamp » Tue Feb 10, 2015 1:03 pm
Whirly,
Looking at an ) O-300C/D instead of the A/B.. As I have one available... :?
Has liked: 75 times
Unread post by Whirly » Tue Feb 10, 2015 1:22 pm
I am confused as I am pretty sure you could use it instead of the A/B? Contact Pete here on AvCom, he will be able to guide you.
paradactyl
Fuelling up
Unread post by paradactyl » Fri May 08, 2015 1:51 pm
I'm looking for an O-300-C. So if you end up unable to use yours, please give me a shout - 083 283 8778
Return to “Cessna”
