Cessna 210
barfly
Re: Cessna 210
Unread post by barfly » Fri Mar 04, 2011 4:03 pm
Same one!!! 3800lbs with a 3-bladed prop. Enjoy, I'm jealous...
zulik
Been liked: 18 times
Re: Cessna 210
Unread post by zulik » Sun Mar 13, 2011 8:26 pm
Would anybody have recent photographs of ZS-MFI? T210N
MemyselfandI
Hee Hee I'm Flying
Re: Cessna 210
Unread post by MemyselfandI » Thu Dec 29, 2011 9:06 am
Would anybody have a POH for a T210 and be willing to share....soft copy ?
Theodore
Re: Cessna 210
Unread post by Theodore » Tue Jan 10, 2012 5:09 pm
MemyselfandI wrote:Would anybody have a POH for a T210 and be willing to share....soft copy ?
I can scan mine and give you a copy. Do not know what the file size would be if it is too big you can collect a copy from me I am based in Pretoria or I can upload to an ftp site.
MemyselfandI
Hee Hee I'm Flying
Re: Cessna 210
Unread post by MemyselfandI » Tue Feb 21, 2012 7:02 pm
Thanks Theo......check pm
Da Vinci
Closest Airfield: Nelspruit
Re: Cessna 210
Unread post by Da Vinci » Mon Apr 15, 2013 12:53 pm
Quick question, the POH says the RPM should be 1700 rpm when the pitch is cycled, KI was taufgt to do power checks at 1700 rpm and before pitch is cycled, increase to 2000 rpm?
So at which RPM should it be done?
One Life - Live it
C185 Driver
Priming
Re: Cessna 210
Unread post by C185 Driver » Tue Apr 16, 2013 8:16 am
Always go with the POH,i do it at 1700RPM on the C210.
Da Vinci
Re: Cessna 210
Unread post by Da Vinci » Tue Apr 16, 2013 9:05 am
Thank you
One Life - Live it
Burger
Closest Airfield: Oranjemund
Re: Cessna 210
Unread post by Burger » Tue Apr 16, 2013 3:50 pm
I was told that cycling the pitch puts a lot of stress on the engine due to the sudden torque change, and it can lead to cracks in the crank-case. I thus only allow the RPM to drop to 1500 before restoring back to 1700.
Da Vinci
Re: Cessna 210
Unread post by Da Vinci » Tue Apr 16, 2013 3:55 pm
Makes sense thanks Wikus, maybe then just cycle it a few times more?
One Life - Live it
Burger
Re: Cessna 210
Unread post by Burger » Tue Apr 16, 2013 4:43 pm
I only do it once.... don't like the idea of stressing the engine.
Da Vinci
Re: Cessna 210
Unread post by Da Vinci » Wed Apr 17, 2013 8:06 am
Even on first starts in the morning?
One Life - Live it
Burger
Re: Cessna 210
Unread post by Burger » Wed Apr 17, 2013 8:18 pm
Yes, but I also give enough time for the oil to warm up before power checks - around 10 minutes.
Da Vinci
Re: Cessna 210
Unread post by Da Vinci » Thu Apr 18, 2013 7:39 am
Thank you for your advise and sharing your knowledge on the 210
One Life - Live it
skydivezimbabwe
Closest Airfield: Charles Prince
Re: Cessna 210
Unread post by skydivezimbabwe » Wed Oct 30, 2013 6:18 am
I am looking for a POH for the 1961 Cessna 210 A (IO-470). We do have a copy - an old, rag eared photocopy thats not very legible and missing a few pages! The aircraft is Z-WCS. Been hangar bound since 2004. It's taken a year to get to the COA test flight. I'll be converting my PPL to CPL and IR in this aircraft. Yesterday's training was cancelled after an ominous ticking sound from the hydraulic power unit indicated an accumulator needing re-gassing. She's all original, never had a wheels up and we're trying to keep it that way! Any help on the POH would be much appreciated.
Return to “Cessna”
