C210 Hotstart
Theodore
Re: C210 Hotstart
Unread post by Theodore » Mon May 30, 2011 8:26 pm
We have both a normally aspirated 210L & Turbo 210R. The following seems to work everytime for me on a hot start
Throttle closed,Mixture idle cutoff
Run pump for approx 90 sec
Full rich
Keep pumping until sufficient pressure
Start cranking & Slowly advance throttle
Fires everytime
Hope this helps
Centurion210
Taxiing to Clubhouse
Re: C210 Hotstart
Unread post by Centurion210 » Mon Jun 08, 2015 3:05 pm
Burger wrote:I have owned C210's for the last 9 years, and always use the following for a hot start:
1) Mixture full rich, full throttle
2) Fuel pump on "high" for a few seconds, until you get some fuel flow
3) Fuel pump off
4) Mixture to idle cut-off
5) Crank the engine with one hand on the throttle
6) The moment the engine fires, reduce the throttle to idle
7) Advance the mixture to full rich
8) Once you have oil pressure, lean the mixture for taxi
It works every time...
I must say I've been flying C210's for 7 years and this method has always worked the best for me.
Return to “Cessna”
