KNS80
Chrisk7
Engine Started
KNS80
Unread post by Chrisk7 » Sat Mar 29, 2014 9:27 pm
I fly a 1981 M20J out of FAGG. Being George, one tend to use your instruments often and need to be able to depend on them. Our KNS80 has been acting up for some time and a week or so ago on the ILS into FAPE the frequencies started resetting to 110.1 within seconds from setting it up. This after the internal bateries has been changed about 2 months ago. Even so, I asume with the Master on the frequencies should only reset on shutdown if batteries were the problem.
The unit is with Hannes at SA Mooney and it seems as though they are struggling to find the fault. If anyone had a similar experience and can point us in the right direction it will be much appreciated?
Return to “Mooney”
