Undercarriage Noise
flashfly
Hee Hee I'm Flying
Undercarriage Noise
Unread post by flashfly » Tue Oct 20, 2009 11:07 pm
My nosegear makes a shuddering noise when taxing over an uneven surface.
Apparently not serious according to a technician. Is it an inherent trait of
Mooneys because they don't have oleos?
Do any other Mooney pilots experience this?
If you let something bother you, IT WILL BOTHER YOU!!!
tailpipe
Re: Undercarriage Noise
Unread post by tailpipe » Thu Oct 22, 2009 8:58 am
Mine certainly doesn't make any noise like that. If the maintance guy says it is fine it should be. However he is not the one being uncomfortable in it. I recommend a second opinion from a experienced Mooney guy. Next time you go past Port Alfred let Pat Hanley take look. (or just call him and explain the symptoms) His opinion is usually sound.
flashfly
Hee Hee I'm Flying
Unread post by flashfly » Thu Oct 22, 2009 6:10 pm
Thanks Tailpipe. Will speak to Pat.
Lood
Been liked: 24 times
Unread post by Lood » Tue Oct 27, 2009 8:50 am
I'll certainly have it checked out - by Pat. It sounds like something is worn out or worse.
I use some reasonably rough strips now and then and have never encountered anything alike.
rod smith
Unread post by rod smith » Tue Nov 10, 2009 6:48 pm
I have never had noise from the front, until the recent collapse/ wheels-up, and then there was plenty. You don't want it, believe me!
Rod Smith
andrem
Unread post by andrem » Mon Apr 29, 2013 8:44 pm
Haha Rod Smith - you were a funny guy ;-).
Return to “Mooney”
