Where to buy 4130
Laika
Where to buy 4130
Unread post by Laika » Tue Dec 04, 2012 10:30 am
Are there local distributors for 4130 steel and 4130 Tig welding rods?
Spruce do sell both but hopefully there is a cheaper option.
Any help appreciated.
Has liked: 685 times
Been liked: 603 times
Re: Where to buy 4130
Unread post by Ugly Duckling » Tue Dec 04, 2012 10:59 am
Placo at Rand have limited stock of tubing.
Check the plans for the grade of rod & talk to Afrox or one of the welding consumable suppliers.
bosvark
Closest Airfield: Rhinopark
Has liked: 17 times
Been liked: 15 times
Unread post by bosvark » Sat Dec 08, 2012 9:46 am
Ugly Duckling wrote:Placo at Rand have limited stock of tubing.
Afrox doesn't know about the existence of 4130 Chrome Molybdenum alloy. Their branch in Pta contacted some technical clevers in the company and I couldn't get helped. In fact, they told me you only get an aluminium alloy designated 4130 :? :?
Same at another "specialist" welding supply shop.
Try Hennie from Infinity aviation 072 383 0453 i.t.o price. 4130 is anyway imported, so will be rather expensive wherever. Are you looking for round tube or streamline tubing? Just asking because streamline is extremely expensive.
Peter Bailey
Closest Airfield: Springs
Unread post by Peter Bailey » Wed Dec 12, 2012 7:56 pm
I bought from Placo recently who imported what they did not have in stock, also try ATS in Jhb west , they import for race car purposes, Chassis shop in USA for direct import , try Thutuka welding in west street , kemp ton park ( formally Tec-dur) speak to Matt, 011 970 1837 for welding rods/ tig rods ,
So much to do , so little time !
StemmeS12 ZT GZG
P Pilot
Reaching altitude
Unread post by P Pilot » Sun Feb 12, 2017 12:14 pm
I came across this post in my search for some 4130 sheet/plate that I'm looking for.
I'm only needing a small amount for my VP1...
Any suggestions of where to source some?
Thanks
homebuilt
Closest Airfield: FAEL
Been liked: 49 times
4130 seamless pipe supplier
Unread post by homebuilt » Mon Feb 13, 2017 11:29 am
I am in need of a piece of 4130 tubing for a repair. Does anybody know if there is a supplier in SA who can supply a short piece of this material. I will be so glad if someone can point me in the right direction. Thanks in anticipation.
Closest Airfield: FAPX
Has liked: 81 times
Been liked: 288 times
Re: 4130 seamless pipe supplier
Unread post by Chalkie » Mon Feb 13, 2017 12:38 pm
What diameter, wall thickness and length?
Wayne Estment used to bring in lots when they were making BearHawk fuselages.
Has liked: 81 times
Unread post by Chalkie » Mon Feb 13, 2017 12:40 pm
What thickness and size?
homebuilt
Unread post by homebuilt » Mon Feb 13, 2017 4:44 pm
I need two pieces seven eighths or 1 inch in dia with wall thickness point zero six five or bigger and 22 inches long. These are the main bearers for the gear and need to be stronger than the mild steel tubing which was used originally. Thanks.
Peter Bailey
Unread post by Peter Bailey » Mon Feb 13, 2017 8:45 pm
Placo at Rand should have . Call att Eric
StemmeS12 ZT GZG
P Pilot
Reaching altitude
Unread post by P Pilot » Mon Feb 13, 2017 8:56 pm
Hi Chalkie,
I'm looking for some 0.09" thick sheet to make up a few pieces 1" wide, varying from 5-7" long to complete the rest of the struts for my VP...
Has liked: 81 times
Unread post by Chalkie » Tue Feb 14, 2017 8:56 am
homebuilt wrote:I need two pieces seven eighths or 1 inch in dia with wall thickness point zero six five or bigger and 22 inches long. These are the main bearers for the gear and need to be stronger than the mild steel tubing which was used originally. Thanks.
Wayne Estement should have. I have one piece 1.125 by .049 by 36 inches
Has liked: 81 times
Unread post by Chalkie » Tue Feb 14, 2017 8:59 am
P Pilot wrote:Hi Chalkie,
I have a piece .125" by 2" wide by 16" long. Thickest plate I have is .063"
lodge
Closest Airfield: fabb
Unread post by lodge » Tue Feb 14, 2017 5:20 pm
I will be going over to the USA soon,and could bring back some small bits for anyone.
homebuilt
Unread post by homebuilt » Wed Feb 15, 2017 8:14 pm
Thanks to all those who replied. I have managed to get what I need.
