Where to buy 4130
P Pilot
Reaching altitude
Re: Where to buy 4130
Unread post by P Pilot » Sat Feb 18, 2017 8:55 pm
Thanks for all the info.
bobthebuilder
Climbing Out
Has liked: 17 times
Unread post by bobthebuilder » Mon Dec 11, 2017 9:03 am
I know it's an old post, but for anyone trolling through in future, Hennie from Infinity Aviation in Kempton Park can bring it in from Aircraft Spruce in the states. It takes about a week to arrive. Max foot length, limited by the size of the airfreight container.
Mauler
Closest Airfield: Vans
Unread post by Mauler » Sun Feb 11, 2018 4:06 pm
Is there a local similar/equivalent alloy that doesn't cost an arm and a leg?
Theuns v V
Been liked: 208 times
Unread post by Theuns v V » Sun Feb 11, 2018 6:38 pm
Iirc the.first.cubs had the front cabin section to the wing TE in 4130 the rear was SAE1010 or 1020. An option maybe....
Has liked: 39 times
Been liked: 318 times
Unread post by heisan » Sun Feb 11, 2018 7:58 pm
Theuns v V wrote:Iirc the.first.cubs had the front cabin section to the wing TE in 4130 the rear was SAE1010 or 1020. An option maybe....
Doesn't the local Bushbaby family use SAE1010?
Theuns v V
Unread post by Theuns v V » Mon Feb 12, 2018 6:03 am
I heard something like that yes , 4130 is a good steel, no doubt but if correctly engineered I am sure 1010 or 1020 does the same thing.
Problem with 4130 is that if you need long sections you need to ship it over sea an it might rust to bits.
T
Pete
Has liked: 76 times
Been liked: 51 times
Unread post by Pete » Mon Feb 12, 2018 10:54 pm
Theuns v V wrote:I heard something like that yes , 4130 is a good steel, no doubt but if correctly engineered I am sure 1010 or 1020 does the same thing.
T
Theuns speak to Ed Knibbs at Alclad :smt023 http://avcom.co.za/phpBB3/viewtopic.php ... 0#p1914743
ed0101
Unread post by ed0101 » Fri Jul 06, 2018 2:45 pm
I have some 4130 tubing and sheeting in stock. Give me a call on 083 251 4601 or ed@alclad.co.za
Jayson v Schalkwyk
Closest Airfield: Himeville
Been liked: 52 times
Unread post by Jayson v Schalkwyk » Mon Apr 13, 2020 11:40 pm
Ed, do you still keep some stuff in stock?
Jayson van Schalkwyk
Induna
Closest Airfield: FASD
Has liked: 91 times
Been liked: 122 times
Unread post by Induna » Tue Apr 14, 2020 7:13 am
I bought some alu sheets from him recently. I don’t know about 4130. Email Ed. He responds quite quickly.
Jacques van der Westhuizen
ZS-WSW | Sonerai 2L
