Major mod documentation?
Airscrewed
Unread post by Airscrewed » Sun Mar 15, 2015 3:09 pm
I am just completing replacing a Rotax engine with a Continental engine. I believe that I nedd to complete a Major Modification document as part of thr re-registration process. I have not been able to locate such document on the CAA website. Can anyone advise please.
Has liked: 44 times
Been liked: 449 times
Re: Major mod documentation?
Unread post by heisan » Sun Mar 15, 2015 8:19 pm
CATS44 wrote:44.01.10 MODIFICATIONS
1. Form
The appropriate sections in Form XYZ1, must be completed in their entirety before the application for modification is submitted to the Director, or the organisation designated for the purpose in terms of Part 149, as the case may be, with the applicable fee as described in Part 187 of these Regulations. All supporting documentation as required by the form must accompany the application.
1 This form is yet to be created.
Seems like the form may not be available. Try contacting NTCA dept directly. Probably best not to mention that the work is already done, as the application for a major mod must be done prior to making the modification...
Airscrewed
Unread post by Airscrewed » Mon Mar 16, 2015 8:54 am
Thanks Justin. Hope to fly my Raven with the O200 alongside yours with the Jabbie. Regards. Joe
Has liked: 44 times
Unread post by heisan » Mon Mar 16, 2015 9:42 am
Airscrewed wrote:Thanks Justin. Hope to fly my Raven with the O200 alongside yours with the Jabbie. Regards. Joe
:twisted: see if you can keep up :twisted:
I seem to remember that someone at RAASA (Willem?) said that they could now handle major mods directly, rather than going through CAA - so contact them first, may be a bit easier.
Airscrewed
Unread post by Airscrewed » Wed Mar 18, 2015 7:35 pm
Cheeky Bugger.............OK I'll put my prop on the correct way and try to keep up.
Will talk to RAASA tomorrow.
Thanks for the tip.
Airscrewed
Unread post by Airscrewed » Thu Mar 19, 2015 2:53 pm
RAASA don,t mamage the major mods. Must go through CAA?
Has liked: 44 times
Unread post by heisan » Thu Mar 19, 2015 3:12 pm
Airscrewed wrote:RAASA don,t mamage the major mods. Must go through CAA?
Can't find the post that mentioned RAASA. Maybe I am imagining things. Here are two recent engine changes - perhaps Wille/Dale can offer advice:
viewtopic.php?f=100&t=93784
viewtopic.php?f=116&t=126887
