JPI700 advice
Taildraggerdriver
Closest Airfield: faps
Has liked: 48 times
Been liked: 24 times
JPI700 advice
Unread post by Taildraggerdriver » Sun Jul 17, 2016 7:05 pm
i need some expert advice for my JPI700, I get erratic readings sometimes, cht probe over reads, then fails, but woeks on start up again, latest snag is ot seems i have lost #6 egt probe, please help
C210
Cirrus sailplane
Aerodon
Been liked: 12 times
Re: JPI700 advice
Unread post by Aerodon » Tue Jul 19, 2016 3:59 am
A few things:
1) the EGT probes wear out, don't count on much more than 1000 hours.
2) the probes have a little nut screw and washer - open up the sleeve, check that the washer is between the two terminals and that it is tight.
3) the JPI use a pretty inexpensive connector with crimped tab type pins. Try reseating the connector on the back of the EDM700, failing that, check that all the pins are properly seated in the connector. I have seen a pin push out of the connector.
Don
Jayson v Schalkwyk
Closest Airfield: Himeville
Been liked: 53 times
Re: JPI700 advice
Unread post by Jayson v Schalkwyk » Wed May 06, 2020 10:52 am
I am also having an issue with my JPI 700. The #5 cylinder "bar" indicators are not displayed, despite the digital temp readouts and I keep getting indications saying EGT high despite the engine being started up from cold.
Jayson van Schalkwyk
Taildraggerdriver
Has liked: 48 times
Re: JPI700 advice
Unread post by Taildraggerdriver » Sat May 09, 2020 3:27 am
The probes, I sold my 180, replaced a probe and all good
In my new plane, brand new JPI830, first EGT probe went at 50 hrs.
Just replace a probe, it’s inexpensive
C210
Cirrus sailplane
Jayson v Schalkwyk
Re: JPI700 advice
Unread post by Jayson v Schalkwyk » Sat May 09, 2020 11:29 am
Yup, did that already on the #5. Maybe its the joints of the pins inside connectors, or maybe a poor ground?
Taildraggerdriver
Has liked: 48 times
Re: JPI700 advice
Unread post by Taildraggerdriver » Mon May 11, 2020 7:34 am
Jason, the probe that failed had a slightly too sharp bend in the lead going to the probe right at the probe,
They are very sensitive sensors,
The solder joints and all connections should also be checked, check your Complete harness for all the probes for integrity.
Un do all the little zip ties, straighten and neaten, and re secure.
I am sure that will solve it
C210
Cirrus sailplane
