Submerged fuel pumps for aviation
Pete
Has liked: 136 times
Been liked: 83 times
Unread post by Pete » Mon Feb 12, 2018 11:08 pm
Found this video very interesting re submerged fuel pumps.
Might also be an option for higher vapour pressure fuels such as automotive or mogas as it is a modern "push" type pump.
Has liked: 825 times
Been liked: 808 times
Re: Submerged fuel pumps for aviation
Unread post by Ugly Duckling » Tue Feb 13, 2018 8:58 am
Could also put the fuel drain valve into the bottom of the vertical header, if mounted low down, as it will be an automatic water trap
