Falcon dual gauge CHT connector diagram.
Wizwheel
Closest Airfield: Virginia
Unread post by Wizwheel » Sun Dec 16, 2018 3:45 pm
Hi All. Can anyone help out with cht connection points polarity at the rear of a Falcon dual cht gauge, ie where the probe pins would connect??
Orthin Opter
Closest Airfield: Tranquility
Has liked: 24 times
Been liked: 47 times
Re: Falcon dual gauge CHT connector diagram.
Unread post by Orthin Opter » Thu Dec 20, 2018 10:26 am
Just google the gauge http://www.falcongauge.com/UploadDriver ... 659645.pdf
I could not find the pinout diagram, but because the thermocouple puts out milli-volts, connect the wires and dunk the tip of the probe in boiling water see if works, if not then just swop the polarity.
