Brake Caliper Seals
bobthebuilder
Rotating
Has liked: 16 times
Brake Caliper Seals
Unread post by bobthebuilder » Mon Mar 11, 2019 6:57 pm
My baby sprung a leak.
The piston inside the brake caliper is leaking. I removed the caliper and the piston and need to replace the o-ring.
I used to get parts like this from Placo, but since they closed up shop last year, I'm stuck.
To further complicate matters, the caliper came off a homebuilt aircraft, so I have no idea what caliper it is. It looks like a Cleveland 30-6, but the seal size is different.
I called East Rand seals, but they can only provide a metric seal, which I'm sure it's not. My feeling is that it should be in the region of 1/8 thick, with an ID of 1.5"
Can anyone help to identify the caliper, and refer me to an agent who can provide the seal.
It looks pretty rough now, so I plan to mask, bead blast, and give it some fresh paint. It would be a good time to rebuild the other one too at this time.
JvTonder
Changing Underwear
Closest Airfield: RhinoPark
Re: Brake Caliper Seals
Unread post by JvTonder » Tue Mar 12, 2019 12:28 pm
Try Seal center in Hermanstad Pretoria, 012 379 6170
Flying feeds the soul!
bobthebuilder
Rotating
Has liked: 16 times
Unread post by bobthebuilder » Tue Mar 12, 2019 4:27 pm
Thanks Jaco.
Jean Crous
Closest Airfield: FASX
Has liked: 168 times
Been liked: 80 times
Unread post by Jean Crous » Fri Apr 12, 2019 9:04 am
Bob, I take it you have come right in the meantime ? The other option is to have the caliper sleeved with a stainless insert, to a metric size slightly smaller, and have the piston cut down in a lathe to fit. Then just do the other side brake as well and , you have metric seals in future :D
Jean.
Cubby Aircraft Factory
Cell : 072 6716 240
RHUBARB
Power on stall
Unread post by RHUBARB » Sat Apr 13, 2019 9:01 am
Spartan Fluid Seal in New Centre Jhb has all the Imperial or metric seals you will need
