Stick on window shades
Has liked: 429 times
Been liked: 255 times
Unread post by Mrb13676 » Fri Aug 16, 2019 1:18 pm
Anyone got any pireps or recommendations for something I can stick onto the inside of the acrylic windows to make them a little darker? Would be for the rear windows on the Sling4, and if dark enough to replace the suction cup shades at the top of the canopy...
Mike Blackburn
ZU-IBM - Sling4 Turbo s/n 009
Tasmag
Closest Airfield: ymlt
Re: Stick on window shades
Unread post by Tasmag » Thu Aug 22, 2019 9:10 am
I tried the standard static version with the holes, it looked good from the inside and did the job. Looked very ordinary from the outside so I removed.
I am thinking about getting some car wrap and trying that on the outside.
Mike
Taildraggerdriver
Closest Airfield: faps
Has liked: 52 times
Been liked: 27 times
Unread post by Taildraggerdriver » Thu Aug 22, 2019 2:17 pm
https://www.aircraftspruce.com/pages/ps ... parmor.php
These work a charm
Not very expensive either
C210
Cirrus sailplane
Unread post by Mrb13676 » Sun Aug 25, 2019 3:49 pm
Mike
I find the supplied shades tend to pull away from the Velcro and I keep touching them with my headset which is why I was looking to replace them with an applied shade.
Mike Blackburn
Unread post by Mrb13676 » Sun Aug 25, 2019 3:56 pm
These work a charm
Thanks - these are essentially very similar to what is supplied with the aircraft - which work well apart from the limitations of the suction cups which wear out and the Velcro around the window frame which sometimes allows the shade to pull away...
Mike Blackburn
Has liked: 888 times
Been liked: 324 times
Unread post by ACE MAN » Mon Aug 26, 2019 4:42 pm
Check these out, You can order it from Amazon.com
Jeep Car Sun 2 Pack Shade, UV Protection, Black
These users liked the author ACE MAN for the post:
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
Unread post by Mrb13676 » Mon Oct 07, 2019 3:31 pm
So just a quick follow up on this post in case anyone else looking for similar...
After looking at the ideas Ace Man posted, I started looking for something similar in SA - and came across a company called Solyx (solyx.co.za) -
Ordered a couple of metres of the stuff, came out to around R500 and they couriered it to me.
It’s a really fiddly job to install but with a bit of patience and care I ended up with a result I’m really happy with - it’s 5% visible light transmission PVC friendly static cling film.
Thanks for the suggestions all.
Mike Blackburn
Has liked: 360 times
Been liked: 355 times
Unread post by V5 - LEO » Mon Oct 07, 2019 8:16 pm
....looks good, static cling - means no glue at all? If so, that is cool.
Unread post by Mrb13676 » Tue Oct 08, 2019 8:07 am
Yep. No glue.
Mike Blackburn
