Looking for supplier
AndyCapp
Unread post by AndyCapp » Fri Feb 21, 2020 11:05 am
Hi Avcommers,
Can someone tell me who can supply me with Avex Countersunk rivets 1/8 inch (1604-0412) and self locking nut plates (NAS 1024NO8K)
Thank you in advance.. :D
Closest Airfield: FAPX
Has liked: 67 times
Been liked: 240 times
Re: Looking for supplier
Unread post by Chalkie » Thu Feb 27, 2020 2:50 pm
Locally Comet Aviation Supplies, but they are closed tomorrow for stock taking. Aircraft spruce have them at 9 US cents ea.
The number given for the anchor nut / plate nut does not seem correct. Aircraft Spruce use MS numbers and plate nuts as used on the RV-series are of the K1000 and K1100 series. I presume you are looking for 8.32 plate nuts?
Do you need a few or hundreds?
AndyCapp
Unread post by AndyCapp » Fri Feb 28, 2020 9:10 am
Hi Chalkie,
Thank you for the reply. I have been getting most of what I need from Aircraft Spruce. Just thought someone might have surplus laying around that they might want to sell off. Import costs far exceeds the price, Especially on small amounts :( I am restoring a BD-5B so I need a few pieces.
Regards,
Andy
Has liked: 178 times
Been liked: 200 times
Unread post by V5 - LEO » Fri Feb 28, 2020 9:36 am
Regards,
Andy
.....what about a few teaser pics???
AndyCapp
Unread post by AndyCapp » Sat Feb 29, 2020 11:12 am
Hi V5,
Just started a month ago. Fixed a few things like brakes, visor, oleo and Rotax water pump. Plane has flowen 119 hours to date. I can only work on it every second month due to overseas commitments. Next will be checking for cracks in the landing gear and flushing and replacement of fuel pipes and a new paint job.
These users liked the author AndyCapp for the post:
Insane
Unread post by V5 - LEO » Sat Feb 29, 2020 11:23 am
....txs and best of luck, how is the cockpit space, very small or adequate for a real grown up? What Rotax is in there? :mrgreen:
AndyCapp
Unread post by AndyCapp » Sat Feb 29, 2020 12:03 pm
Its is a little tight but adequate. It has a Rotax 582..
Unread post by V5 - LEO » Sat Feb 29, 2020 1:42 pm
..oh great. Where abroad do you operate USA? If so, do check out some of the airboat facilities, they have made tremendous leaps in the potential of pusher props - just saying :D enjoy every moment of this adventure.
AndyCapp
Unread post by AndyCapp » Sun Mar 01, 2020 7:38 am
Hi ,
I work in Qatar (Engineer for Rolls Royce) but live in Welkom.. :D
Unread post by V5 - LEO » Sun Mar 01, 2020 9:35 am
... #-o then you can figure all out for yourself :D :D , enjoy life man :D
MadMacs
Closest Airfield: GRJ
Has liked: 428 times
Been liked: 88 times
Unread post by MadMacs » Sun Mar 15, 2020 10:30 am
What about Avdel in Boksburg?
I'm not old, I'm 18 with 47 years of experience :D
AndyCapp
Unread post by AndyCapp » Mon Mar 30, 2020 5:24 am
The Nut plates I need is:- MS21078-08
