Q regarding weather radar
South African Weather Service.
kb
Unread post by kb » Wed Dec 30, 2015 9:54 pm
Question. If I look at the durban weather radar underberg and kokstad fall at 150 & 200 nm respectively. Would a storm cell in those areas show as accurately as they would closer to durban. Does the weather radar pick up the storm tops only, as line of sight would be affected by the miles of land and hills between durban and underberg? Meaning, would a storm cell on the radar be lot bigger than actual, and in that case it may not show at all unless it has enough vertical development. Hope that makes sense.
There are no stupid questions, only stupid people.
tanglefoot
Has liked: 14 times
Re: Q regarding weather radar
Unread post by tanglefoot » Wed Jan 06, 2016 9:38 pm
kb wrote:Question. If I look at the durban weather radar underberg and kokstad fall at 150 & 200 nm respectively. Would a storm cell in those areas show as accurately as they would closer to durban. Does the weather radar pick up the storm tops only, as line of sight would be affected by the miles of land and hills between durban and underberg? Meaning, would a storm cell on the radar be lot bigger than actual, and in that case it may not show at all unless it has enough vertical development. Hope that makes sense.
As you are unlikely to get an official response from saws I will try to help.
Yes ,within 200nm the storm cells will show accurately. The red markings and arrows showing the direction of the storm are added manually and could change, or be wrong. These things are moving at 50km/h or more at times so are difficult to pin down.
The radar is definitely line of sight but, as far as I know, it picks up moisture over a relatively broad altitude, increasing with distance. Storm tips are often above 10000ft agl so pretty high and could be above the weather radar. The height above ground of the moisture is not possible to determine.
The biggest problem with weather radar is what lies behind the reflections. You can often see storm cell with what appears to be clear weather behind it. It is more likely that the radar can't penetrate beyond the storm cell.
Have a look at the spot graphs on the aeroclub pages. It will give you a better idea of the moisture content and potential cloudbase. It is a forecast but read in conjunction with the radar and other info is pretty good.
For the best available info just pm FAPE on avcom.
kb
Unread post by kb » Tue Jan 12, 2016 8:20 pm
Thanks for the reply Tanglefoot. yes, all makes sense, I was just not sure how accurate the actual size of the storm would be shown at such a distance. I suppose 200nm with a increase in terrain elevation is small change compared to the altitude of the storm cells.
tanglefoot
Has liked: 14 times
Unread post by tanglefoot » Tue Jan 12, 2016 9:04 pm
kb wrote:Thanks for the reply Tanglefoot. yes, all makes sense, I was just not sure how accurate the actual size of the storm would be shown at such a distance. I suppose 200nm with a increase in terrain elevation is small change compared to the altitude of the storm cells.
I read an article online that said that the resolution at 200nm is around 1km x 1km, so a pretty big chunk of sky. "Ground clutter" is largely programmed out of the display but the radar is still line of sight and storms may be shielded behind high ground.
Treat radar info with circumspection. Even in the short term storm cells come and go faster than the pictures are refreshed on aviation.weathersa.co.za. If you feel like dodging thunderstorms then weathersa is not a good source :D
Even though it shows forecast directions of existing storm cells these change rapidly. It largely only tells you where the storm was at a specific time.
Google "weather radar". There is quite a bit of info out there.
FAPR
Closest Airfield: FAWK
Unread post by FAPR » Sun Jun 19, 2016 3:12 pm
kb wrote:Would a storm cell in those areas show as accurately as they would closer to durban?
A thunderstorm would often (but not always) appear larger the further away it is from the radar. What happens is the beam width increases the further away it travels from the radar, so much so that when the beam (which is now very wide at 200 km) is filled only partially by say, the top of the thunderstorm, the radar software will think the whole beam is filled, and therefore make it appear larger on the display. So yes, the storm is represented most accurately the closer it is to the radar. See the attachment of an example. The arrows point to the same storm but on different radars (Irene & Ermelo)
kb wrote: Does the weather radar pick up the storm tops only, as line of sight would be affected by the miles of land and hills between durban and underberg?
Considering thunderstorm tops reach on average 10 km, you will still see a good deal of the thunderstorm, anything from 3-4 km and above. So only the lower elevation scan of the beam will be blocked by the escarpment. Stratiform rain however might be missed completely since these occur at much lower altitude.
tanglefoot
Has liked: 14 times
Unread post by tanglefoot » Sun Jun 19, 2016 9:40 pm
At the end of July this information will no longer be available free of charge. Another tax on the GA pilot and in my opinion just one more tool for aviation safety available to all first world pilots (we are a first world country aren't we?) that we will no longer have access to. Soon the CAA will need to take responsibility for weather related aviation accidents. After all, it is their responsibility to create a safe environment for GA.
kb
Unread post by kb » Mon Jun 20, 2016 12:24 pm
Thanks for the answers FAPE. clears it up abit.
Return to “SAWS”
