Rail gun build # Completed #
Theuns v V
Has liked: 14 times
Been liked: 89 times
Unread post by Theuns v V » Sun May 12, 2013 2:47 pm
Mike asked me to build him 2 "funfly" aeries for the upcomming Fun fly Masters.
Here is what I have done.
WIngspan is 1150mm. Closed loop cables for the tail controlls. The nose was extended by 30mm to allow for the electric power setup, from there the name "rail gun" :wink:
One thing though was that these planes had to be super light as in the Masters every gram counts. The airframe as you see here weighs in at 320 gr and I am hoping for less than a 1KG MAUW......stay tuned.
I might just have to build one of these for myself aswell :D
T
Mike Brews
Closest Airfield: Barnstormers
Re: Rail gun build
Unread post by Mike Brews » Sun May 12, 2013 3:48 pm
Thanks Theuns, looking good. Now to get all the other hardware into them
:D Mike
Kind Regards
Mike Brews
074 303 1533
brews.mike@gmail.com
"Aviation, like the sea, is not inherently dangerous; but it is terribly unforgiving of any carelessness, incapacity, or neglect"
Theuns v V
Has liked: 14 times
Re: Rail gun build
Unread post by Theuns v V » Sun May 12, 2013 4:17 pm
Covering to go on first :) :)
Mike Brews
Re: Rail gun build
Unread post by Mike Brews » Wed May 15, 2013 11:19 pm
Hi Theuns,
More pics please. I am looking forward to seeing them fly
Mike
Kind Regards
Mike Brews
074 303 1533
Theuns v V
Has liked: 14 times
Re: Rail gun build
Unread post by Theuns v V » Thu May 16, 2013 6:34 pm
Bothe airframes complete, will post of covered aerie this weekend :)
T
Mike Brews
Re: Rail gun build
Unread post by Mike Brews » Thu May 16, 2013 9:15 pm
Hi Theuns,
How long to finishing these little beauties of yours? Time to start flying. :D
Kind Regards
Mike Brews
074 303 1533
madjake
Steep Turn Left
Closest Airfield: Virginia
Re: Rail gun build
Unread post by madjake » Fri May 17, 2013 8:42 am
Looking good T
watching you fly past Cooper Lighthouse
Theuns v V
Has liked: 14 times
Re: Rail gun build
Unread post by Theuns v V » Fri May 17, 2013 8:51 am
Thanx mate. I must say with weight being so super critical here the wood selection was important, but it makes building and ahndling the uncovered model rather dufficult.
We have 90 % size and wing area of the original "funfly" but I am aiming for about 70-80% of the original's allowed weight (lighter wingloading), so in theory it should be able to outperform it.......stay tuned.
T
madjake
Steep Turn Left
Re: Rail gun build
Unread post by madjake » Fri May 17, 2013 2:40 pm
Hi T
I am about ready to cover a shotgun wing for a mate of mine, I covered mine starting on the open rib panels then the LE. and lastly the wing tips. Is there any reason to do it differently?
blender
Closest Airfield: FAVG
Has liked: 25 times
Re: Rail gun build
Unread post by blender » Fri May 17, 2013 5:15 pm
Hi Mark
FWIW, I'd do it exactly the same.
Tailheavy !!!!! naaaaaaaaaaa
You are never READY for a Lipo fire
Be the Lion
Beware the "googleneers"
Theuns v V
Has liked: 14 times
Re: Rail gun build
Unread post by Theuns v V » Fri May 17, 2013 6:40 pm
Mark it sound right to me mate. I try to put the darker colors over the lighter where the joint are as some clorls like yellow and red sometimes show the dark under coler through the joint.
WHere I can I try to start at the trailing edge side and work forward so the joint it inline with the airflow, but I think when correctly done it is not so critical.
The tips on there thick wing aeries are damn hard to cover without making a slit in the plastic somewhere and puting a small re-enfircement strip over the joint.
T
Mike Brews
Re: Rail gun build
Unread post by Mike Brews » Mon May 20, 2013 11:06 am
PICTURES PLEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEESe
Kind Regards
Mike Brews
074 303 1533
Theuns v V
Has liked: 14 times
Re: Rail gun build
Unread post by Theuns v V » Mon May 20, 2013 12:19 pm
I will email it to you. I am having a hard time uploading to avcom, keep giving a "internal 500 error" :evil:
#1 just needs a 1/2 of the fuse in blue, the wing is done aswell as the tail and ailerons , ready for hindging.
#2 is ready for covering.
T
Mike Brews
Re: Rail gun build
Unread post by Mike Brews » Mon May 20, 2013 2:50 pm
Thanks, we are all dying to see them.
Kind Regards
Mike Brews
074 303 1533
Theuns v V
Has liked: 14 times
Re: Rail gun build
Unread post by Theuns v V » Tue May 21, 2013 4:38 pm
Next hindging, hatch and electronics instelation.
T
Return to “General Model Aircraft Chatter”
