Depron Cargo Plane Build (ft-guinea)
- Lining Up
- Closest Airfield: ME AND ME ALONE
- Been thanked: 1 time
Re: Depron Cargo Plane Build (ft-guinea)
Not a good idea building differentails in to the control linkages......just saying
37OHSSV O773H
- Closest Airfield: Rand Airport
- Has thanked: 7 times
- Been thanked: 5 times
Sorry for the dof question.. but what does that mean??davidbejamin wrote:Not a good idea building differentails in to the control linkages......just saying
Yank & Bank Dutchman
Bunch of airies.. the cheaper the better!
All on HITEC Mode 2.. Woohooo!
- Changing Underwear
- Closest Airfield: Virgina
- Been thanked: 0
Taping it like I did was a kaak idea lolGeorge.vdH wrote:Mmmm! I had a similar prob with my spoeg-&-plak twin. I ended up making the engine nacelles longer & fitting HUGE motors i just happened to have. My a.u.w was 1.6kg... of which the fuse was only 400g! I didnt tape anything like u did.
Bit of rework and off she goes!
It added so much weight, next time I will only tape bits that bend and need strength.
I moved the wing back towards the tail today and it seems to have sorted the CG. I would think it needs to come forward like I tried. Will take it to the field and ask the guys for advice.
Just Fly!
- Been thanked: 0
Yeah, I'm confused ^_^George.vdH wrote:Sorry for the dof question.. but what does that mean??davidbejamin wrote:Not a good idea building differentails in to the control linkages......just saying
Just Fly!
- Fuelling up
- Closest Airfield: Roodepoort Flyers
- Been thanked: 0
Re: ft-guinea-build (cargo plane)
jeandredubois wrote:Hier is my Guinea Pig
Ek het my planne vergroot na 150% & daarom weeg myne so baie...
Vlerkspan so net oor die 1700mm
Moet nog hier & daar 'n sticker plak, maar verder is ek happy.
Bietjie meer as 1:1 krag verhouding, maar vlieg 18min (rustig - Vertrou nie die foam vlerk met daai gewig nie) met 'n 4sel 5000mah
Aerie weeg 2.2kg & thrust is 2.6kg
Dit lyk Stunning!!!
NS: Like jou slagspreuk Tjomma!!!!
Thank you kindly,
Willie
Warbird Junky
Willie
Warbird Junky
- Been thanked: 0
Sadly this plane was just too heavy and I stripped it for parts.
Lesson learnt - dont cover depron in ductape!!
Just Fly!
What span was that?
I think 2mm correx might have been a better choice of build material than foam and tape. Lighter than SA foamboard, tougher than depron and easy to paint. Ask George, he's a recent convert. But beware, it's addictive. Once again, ask George
I've got similar motors on a 1.3m span twin that weighs ~800g (IIRC) and a 1.4m Vulcan that weighs 1.6kg. Both have plenty of power. I've got the 1500KV versions and use 8x4 props and 20A ESCs. Because the current is so low, I only use one 2200 LiPo...saves almost 200g.
Actually, the P68/ Twin Otter lookalike twin was originally built with a foam board empennage, but I replaced it with 2mm correx when I realized how heavy the FOM+ board really is.
You just need to remember 2 mantras:
1) "Every gram is sacred" (Paraphrased from Monty Python)
2) "Stronger is heavier is weaker"
Yup.. Stronger is heavier is weaker!
I used to build planes strong so the are crash proof.. no such thing! Build light.. it will fly right so i dont have to crash!!
I've never used packing tape on my airies. Recenly been going smaller and lighter with my motors and batts. The results have been very pleasing.
