Sling 4 build Morningstar
checkride
Re: Sling 4 build Morningstar
Unread post by checkride » Sun Mar 27, 2016 6:34 pm
here are the drawings of thre long Range tanks as you can see not much detail battling a lot to make head or tail of this
checkride
Unread post by checkride » Mon Mar 28, 2016 10:03 pm
Busy day today worked about 8 hrs. Prepared all the bottoms skins for the right wings. Not enough thinners so could not do the priming. Prepped all the parts for the two auxiliary tanks. Constructed same to ensure all parts fit correctly. Sent photos to the factory , need to know if the brackets are correct as the documentation is not good.
Need to decide on plumbing, facet pumps and sensors for both these tanks :D :D ...me too
checkride
Unread post by checkride » Mon Apr 04, 2016 11:02 pm
Busy last few days all 4 tanks have been constructed , match drilled , deburred , cleaned. Started with the main tanks today sealing fitting etc . Want to try and get at least one tank done tomorrow. Still waiting on some parts from the factory.,,,remember when... :D :D
Auxiliary tanks will not get level sensors plan has changed a bit.
checkride
Unread post by checkride » Tue Apr 05, 2016 7:29 pm
Well spent the whole day doing one tank. Im sure that the next will go a lot quicker. There is no easy way to work with this tank Sealant, plenty gloves , Acetone , Patients and old clothes. Have the over flow to do and the fuel cap then onto the second tank. Might take the time to add some more sealant to the inside just in case.... :D :D מתגעגע אליך :D :D
Has liked: 440 times
Been liked: 177 times
Unread post by Fransw » Tue Apr 05, 2016 7:37 pm
Hi Checkers, is this a quick build kit?
Keep up the good work!
checkride
Unread post by checkride » Wed Apr 06, 2016 7:06 am
Nope don't think they do a quick build kit its a box of parts
checkride
Unread post by checkride » Thu Apr 07, 2016 8:12 am
Yesterday finished the left inboard tank and started on the right. Bent the overflow pipe work and finalised the level sensors on both tanks.
checkride
Unread post by checkride » Thu Apr 07, 2016 9:26 pm
Today finished sealing tank 2 tomorrow we start on the auxiliary tanks. I have a new product arriving EC-766 which is a 3M product. This is a paint of sealing agent or a flushing solution whichever one want to use. There is NO damn chance that these tanks will leak. Going to test on the auxiliary tanks by using PRC then painting EC-766 then testing. Have faith..we shall see
checkride
Unread post by checkride » Tue Apr 12, 2016 8:17 pm
So completed all the insides of all 4 tanks , just waiting for the auxiliary tanks to dry before I coat with EC-766. Going to seal up all the tanks and pressure test with air. I have faith. And hopefully that will be the end of the tanks and back to the wing, will be a huge milestone
" Everyday I remember something" must remember to write it down. :lol: :lol:
Must be the cement....
checkride
Unread post by checkride » Tue Apr 12, 2016 8:21 pm
Anyone need there tanks done call me...
checkride
Unread post by checkride » Wed Apr 13, 2016 10:37 pm
One done 3 to go...5 days then the test in the meantime after tomorrow i can get back to the right wing and get those lower skins in place. I have two hatches to cut on the outboard skin, something the factory didnt plan for...How is one supposed to install the tanks or remove them if there is no access...duhhh. Have I missed something. So I was told to cut my own okiedokie...like i was told to cut off the tie down from the main spar.....well see about that [-X [-X
Seank
Closest Airfield: Bomac
Been liked: 12 times
Unread post by Seank » Thu Apr 14, 2016 7:11 am
Gary / Rael that is looking awesome I must pop by one weekend. Come see this in the flesh.
http://www.seankriegler.com
Remember - "you only find out who is swimming naked when the tide goes out"
CNC Foam cutter building a new one
YES, I did it!!! I can now CNC cut epoxy glass and carbon fibre servo horns...
checkride
Unread post by checkride » Thu Apr 14, 2016 8:35 am
Anytime bud....always there :D
checkride
Unread post by checkride » Thu Apr 14, 2016 9:41 pm
Boring more tanks, two done today one left for tomorrow. Started preparing the fittings for the landing lights, might get that done and dusted tomorrow.
Some parts arrived from the Sling Factory, much to my amazement we had to open all the boxes sent to find a small packet of goodies. Would of been nice if we were given a box number but suppose that was just too easy.
I have another list ready to send of missing items.....
So tomorrow finish the tanks, do the landing lights. Saturday Braai , Sunday Breakfast run ...need some time away from this build . Monday back full swing I hope... :lol: :lol: remember when damn oh well. :D :D
checkride
Unread post by checkride » Fri Apr 15, 2016 10:56 pm
All the tanks completed , start testing on Monday. Stb side Landing lights done .
Tomorrow Port side to be done. Want to start Skinning the underside of the stb wing, well thats the plane....Things never go according to plan as I recall [-(
Return to “Sling”
