Sling 4 build Morningstar
checkride
Re: Sling 4 build Morningstar
Unread post by checkride » Sat Apr 16, 2016 9:20 pm
Finished the landing Lights and all the vent lines for all 4 tanks.
checkride
Unread post by checkride » Sat Apr 16, 2016 9:24 pm
Decided to finish the rear spar assembly for the left wing. Major issues. Either i have messed up badly or the factory has messed up big time . I really dont know whats going on here but the rear spar channel extension does not fit. I have 4 to try from all of them are the same. Am I missing something here. Look at these pictures maybe someone else sees something I am not but from what Im seeing it looks like the bend angle of the channel is ass about face.
checkride
Unread post by checkride » Sat Apr 16, 2016 9:28 pm
More pictures.....
checkride
Unread post by checkride » Mon Apr 18, 2016 5:30 pm
Ok,
So we found the issue . The rear spar bend is incorrect its ass about face where the 90 deg bend is supposed to be at the bottom and the angle on top its the other way round. Compared this to another spar. See for yourselves in the attched photos.
checkride
Unread post by checkride » Wed Apr 27, 2016 10:10 pm
So today, completed the rear spar and channel extension. Completed the skins underside for the right wing, dipped sprayed. Tomorrow need to mark out the inspection hatches for the long range tanks and cut out same......
checkride
Unread post by checkride » Fri Apr 29, 2016 2:05 pm
Wing Angle 7 on Rib 4 on both left and right wing has been bent incorrectly. Confirmed the measurements with the Factory. Sideslip again assisted today with replacing these two brackets so the job can continue. Did the left wing and test fitted the rib all good now.
:D :D
checkride
Unread post by checkride » Fri Apr 29, 2016 2:10 pm
Today received the Engine mount for the Jabiru Engine....And a Timex Rotax 912 ULS which will be overhauled and sold. Maybe with EFI or Big Bore kit still trying to decide what to do.
The engine will be zero timed with parts and crank supplied from Edgeperformance in Norweigh . Crank is X-Factory
checkride
Unread post by checkride » Tue May 03, 2016 7:35 am
Wanted to finish the Right wing this weekend but ran out of Cleoco's so will continue during the week. Also started stripping the 912 for overhaul as the crank and other parts needed will be here later this week.
checkride
Unread post by checkride » Tue May 03, 2016 9:43 pm
so turned the wing over , marked up where the inspection hatches needs to be . Checked the position of the brackets for the long range tanks, removed the old tie down bracket then went back to stripping a Rotax engine..
checkride
Unread post by checkride » Wed May 04, 2016 8:07 pm
Inspection Hatches done, now I can rivet the bottom skins and move on and finish this damn wing, ok i didnt mess up it just looks a bit out of shape .....remember :D :D
checkride
Unread post by checkride » Sun May 08, 2016 11:46 pm
So wanted to finish up the testing of the tanks but surprise no luck as there is an issue. Rib 117 on the extended fuel tanks has been damaged by the tooling , see for yourself. This will have to be repaired in place as removing it is not an option.
checkride
Unread post by checkride » Sun May 08, 2016 11:48 pm
Finished installing the rivnuts in the Stb Wing inspection hatches.
checkride
Unread post by checkride » Thu May 12, 2016 9:29 pm
So after speaking to a few people and not doing what the factory wanted me too do we installed the doubler on the inside. We had to cut an access hatch to the back channel of the tank to install the double from the inside , worked out well.
checkride
Unread post by checkride » Sun May 22, 2016 11:45 pm
Great tool for doing those big skins,,,,,no more smooth fingers.....remembering now.
checkride
Unread post by checkride » Sun May 22, 2016 11:47 pm
Today finished up spraying all the skins except one. Damn 3M mask blocked up so had to stop. This etch primer is nasty stuff rather safe than sorry. Now I can finish up the wings yea baby a huge milestone for me.....
Return to “Sling”
