Sling 4 Cape Town
gordloewen
Closest Airfield: KLWM
Re: Sling 4 Cape Town
Unread post by gordloewen » Mon Mar 28, 2016 11:39 pm
Just in case no-one has mentioned this to you yet, the orientation of the rear fuselage short stringers (RF-LGN-902) in the instruction manual (2014/02/19 revision) is incorrect - the left and right stringers need to be swapped with each other to get the correct orientation to enable the rear fuselage to mate with the center fuselage.
See my blog http://www.gordlsling4.com/2016/03/cont ... elage.html that has a photo that indicates the incorrect positioning.
Gord
Lo-Ammi
Taxiing
Closest Airfield: Morningstar
Unread post by Lo-Ammi » Wed Mar 30, 2016 10:23 pm
Thanks Gord, I saw that on your blog this past weekend. Have to drill mine out as well
Lo-Ammi
Taxiing
Unread post by Lo-Ammi » Tue Aug 09, 2016 7:28 pm
Completed the rear fuselage
Lo-Ammi
Taxiing
Unread post by Lo-Ammi » Tue Aug 09, 2016 7:31 pm
Doing as most wiring and fitting before attaching the 2 fuselage pieces and side panels
Lo-Ammi
Taxiing
Unread post by Lo-Ammi » Tue Aug 09, 2016 7:40 pm
Attaching the rear and center fuselage sections and side panels
Lo-Ammi
Taxiing
Unread post by Lo-Ammi » Tue Aug 09, 2016 7:41 pm
Attaching the landing gear.
checkride
Unread post by checkride » Tue Aug 09, 2016 10:53 pm
Very Nice Work looking good now you can come motivate me a bit
Lo-Ammi
Taxiing
Unread post by Lo-Ammi » Sun Oct 16, 2016 7:01 pm
Test fitting
Lo-Ammi
Taxiing
Unread post by Lo-Ammi » Sun Oct 16, 2016 7:03 pm
I had the canopy sprayed on the inside before fitting it.
The back stuff is really nasty to work with
Lo-Ammi
Taxiing
Unread post by Lo-Ammi » Sun Oct 16, 2016 7:08 pm
Some work on the inside
- pulled through the wiring for the cabin lights
- sealed the ducts for the rear vents (used the nasty black stuff again)
- fit the seat belts
Drilled the holes for the parachute cover
Lo-Ammi
Taxiing
Unread post by Lo-Ammi » Sun Oct 16, 2016 7:12 pm
Test fit the firewall forward parts, cut templates and glued the heat shield.
I made a heat shield for the gascolator (bottom right)
Lo-Ammi
Taxiing
Unread post by Lo-Ammi » Sun Oct 16, 2016 7:50 pm
SideSlip started spraying the wings, control surfaces & empennage
Lo-Ammi
Taxiing
Unread post by Lo-Ammi » Sun Oct 16, 2016 7:52 pm
Engine mounted
Lo-Ammi
Taxiing
Unread post by Lo-Ammi » Sun Oct 16, 2016 7:56 pm
Fuselage ready for painting. Started on the Panel
Lo-Ammi
Taxiing
Unread post by Lo-Ammi » Sun Oct 30, 2016 7:12 pm
Transporting to the hanger
Return to “Sling”
