For Sale: Mooney M20C
Forum rules
No commercial adverts please (If your intended post is of a commercial nature, then please follow this link and read BEFORE you post : http://www.avcom.co.za/phpBB3/viewtopic.php?t=54617). If you are advertising for a friend - the ad must contain the owners contact details. If you wish to advertise in the commercial section: - email ads@avcom.co.za for more information. Model Aircraft and non aviation item's have their own section - any posted here will be deleted.
Vogoff
Closest Airfield: FASY
Has liked: 22 times
Been liked: 53 times
Re: For Sale: Mooney M20C
Unread post by Vogoff » Mon Apr 27, 2020 6:58 pm
Rotor kop wrote:
Mon Apr 27, 2020 8:21 am
What block speed do you get and fuel burn please, also payload with full tanks, range? I am asking because google brings up way to many different figures. Better to get your actual figures. Thank you.
You can find a POH here:
https://www.manualslib.com/download/133 ... -M20c.html
From experience I plan for 135 knots ground speed averaging around 32l/hour (properly leaned) @ FL095. With full tanks (200l) that gives around 5.5 hours endurance (with 45 minute reserve) and an approximate range of 750nm.
The POH says that at 2400 RPM and 19" you should get around 135 knots, 30l/h, endurance 5h37, and range of 760 nautical miles. So my experience is not too far from the book value.
Unfortunately my weight and balance is in the aircraft so I don't have the exact numbers in front of me, but according to my app I can carry 285kg (630lbs) with full fuel tanks.
Hope this helps.
Matthew French
ZS-DWU Mooney M20C
Rotor kop
Closest Airfield: OR Thambo
Has liked: 904 times
Been liked: 106 times
Unread post by Rotor kop » Mon Apr 27, 2020 8:45 pm
Hope this helps.
Thank you =D>
Vogoff
Has liked: 22 times
Unread post by Vogoff » Sun May 31, 2020 5:30 pm
Managed to do my maintenance flight yesterday. DWU flew beautifully. Can't say the same about the pilot who is clearly a little out of practice. :oops:
Unfortunately (for me) my AMO has informed me that my propeller is due for its 10 year overhaul at the next MPI, which will dent the bank account. Therefore I am dropping the asking price until the end of July. It is not really a discount, but I only think it is fair in the circumstances.
Matthew French
ZS-DWU Mooney M20C
Pine
Unread post by Pine » Thu Jun 11, 2020 12:48 pm
What is the cost on the prop overhaul and the yearly MPI?
Vogoff
Has liked: 22 times
Unread post by Vogoff » Thu Jun 11, 2020 2:01 pm
I don't have an exact number for the MPI because I use the opportunity to fix other snags and maybe do an upgrade or two. Base cost was around R12k when I last asked, but there is always some more work to do so I budget around R20k.
I don't have a quote for the prop overhaul, will only get one once the prop is removed from the aircraft. But the best guesstimate I could extract was around R30k for an overhaul.
Matthew French
ZS-DWU Mooney M20C
Lood
Been liked: 76 times
Unread post by Lood » Thu Jun 11, 2020 4:13 pm
Sounds about right. Prescribed hours for this Mooney are 22, so just multiply that by the hourly rate of your AMO and add the extra's. Average MPI cost on my M20F was R23K.
No idea what the prop overhaul costs are these days.
AndyCapp
Unread post by AndyCapp » Sun Jun 14, 2020 5:28 am
Just received a quote on my M20J amounted to 41K.
Francoisc
Priming
Has liked: 11 times
Unread post by Francoisc » Sun Jun 14, 2020 9:33 pm
My M20J just came back from MPI at SA Mooney, just under 35K incl vat, and that includes a new tire.
And SA Mooney is not exactly the the cheapest place for an MPI by a long shot, but the work they do is worth the price you pay.
Good luck with the sale
gerritv
Preflighting
Closest Airfield: EFA
Unread post by gerritv » Mon Jun 15, 2020 2:03 pm
I also heard that the Mooneys mpi's are around R25k - R35k.
AEH
Airborne from Unmanned field
Has liked: 44 times
Unread post by AEH » Wed Jun 24, 2020 9:02 pm
Lovely aircraft that is pampered by her owner.Good value for anyone who buys her.
Alan Evan-Hanes ZU-ASI PA-18-150
083-325-5654
Vogoff
Has liked: 22 times
Unread post by Vogoff » Thu Jul 23, 2020 12:05 pm
ZS-DWU is now at Rand Airport for the MPI.
Matthew French
ZS-DWU Mooney M20C
Vogoff
Has liked: 22 times
Unread post by Vogoff » Wed Aug 05, 2020 8:50 pm
MPI completed - DWU now has a freshly overhauled prop and magnetos. And a fresh CofA.
For the curious: the MPI came to R67k. But this was a much more expensive annual than usual - half the cost was just the prop.
Could be worse - I see YouTuber Steveo1kinevo's TBM cost USD93k for its annual. Yes - that is US dollars! :shock:
Matthew French
ZS-DWU Mooney M20C
Vogoff
Has liked: 22 times
Unread post by Vogoff » Thu Sep 10, 2020 9:24 am
*bump*
Aircraft is still for sale. Although running so smoothly after the MPI I must confess I was having second thoughts. Uhm... that and the fact that the aircraft I was looking at were all sold before I could make an offer, so my original reason for selling went away.
I have resolved it is time for a change. I love my Mooney, but life is too short to spend it with one aircraft and my bank manager won't let me own two...
Matthew French
ZS-DWU Mooney M20C
ByronPilot
Tripped over wheel chock
Has liked: 12 times
Unread post by ByronPilot » Sun Sep 13, 2020 7:43 am
Very nice mooney. They are very good value for money
Mine was a very reluctant sale when I upgrAded
Would have loved to keep her
Return to “Aircraft for Sale”
