Zenair 601 For Sale R215K (SOLD)
Forum rules
No commercial adverts please (If your intended post is of a commercial nature, then please follow this link and read BEFORE you post : http://www.avcom.co.za/phpBB3/viewtopic.php?t=54617). If you are advertising for a friend - the ad must contain the owners contact details. If you wish to advertise in the commercial section: - email ads@avcom.co.za for more information. Model Aircraft and non aviation item's have their own section - any posted here will be deleted.
Induna
Closest Airfield: FASD
Has liked: 127 times
Been liked: 145 times
Re: Zenair 601 For Sale R215K
Unread post by Induna » Thu Jul 16, 2020 9:03 pm
Roger wrote:
Thu Jul 16, 2020 8:25 pm
What effect does the 912X upgrade have on the recommended TBO?
On condition, because technically it is not n Rotax anymore (or that’s what i have been told)
Jacques van der Westhuizen
ZS-WSW | Sonerai 2L
Farley
Closest Airfield: Panorama airfield
Unread post by Farley » Fri Jul 17, 2020 6:53 am
Induna, thanks for hearsay comment about Rotax motors metamorphing when you change a washer on them.
I can always count on you, hijacking some body's post and adding your 2 cents .
Induna
Unread post by Induna » Fri Jul 17, 2020 7:15 am
No i think it is actually a valid comment, even if its hearsay.. let's hear what the experts (like yourself) have to say. If you have nothing positive to add then rather refrain from posting
So let me explain. If you change the pistons on the 912 (like the XTRA kit), then all parts in the 912 are not Rotax original, hence Rotax will not honor a warrantee (if it was still in that period). Basically, it is not a Rotax original product (like the complete engine) so technically speaking it does not have to comply with the 12 year or time based requirements (which are recommendations by the way), hence then being run "on condition". Ask the AMOs that add aftermarket turbos and superchargers or Edge Performance kits to these engines and they will tell you the same thing.
I am not talking about changing washers. Use your common sense and stop making silly comments.
Mike, sorry for the hijack... This aircraft is worth every cent. Good luck with the sale.
ZS-WSW | Sonerai 2L
bluesmancoops
Unread post by bluesmancoops » Fri Jul 17, 2020 8:11 am
As far as I am aware - because the engine was opened and "re-done" at around 250 hrs it is the same as an overhaul so the TBO is shifted by an extra 250 hrs and it does not affect the over all TBO time of 1500hrs
Mike Cooper
Flying is not a habit ... it's an addiction
Farley
Unread post by Farley » Fri Jul 17, 2020 8:19 am
I made my point !
Has liked: 1319 times
Been liked: 434 times
Unread post by Ray W » Fri Jul 17, 2020 10:14 am
Moderators Message:
Gentlemen, keep it civil please
Roger
Closest Airfield: FAPE
Has liked: 123 times
Been liked: 275 times
Unread post by Roger » Fri Jul 17, 2020 10:18 am
Thanks Bluesmancoops. Good luck with the sale. I doubt this one is going to be around too long.
Faraway
Closest Airfield: Morningstar
Has liked: 12 times
Unread post by Faraway » Tue Jul 21, 2020 3:34 pm
Still for sale?
bluesmancoops
Unread post by bluesmancoops » Tue Jul 21, 2020 4:02 pm
yes it is
Mike Cooper
Faraway
Has liked: 12 times
Unread post by Faraway » Sun Jul 26, 2020 6:57 pm
Sunday night bump...
LimaK
Engine Still Cranking
Closest Airfield: FBSK
Unread post by LimaK » Mon Jul 27, 2020 2:06 pm
Is this the same aircraft as the Zodiac CH601XL? I have tried in vain to get the specs from Google for Zenair 601.
bluesmancoops
Unread post by bluesmancoops » Mon Jul 27, 2020 2:55 pm
Hi Limak - no it is not the same - it is closer to the South African Raven aircraft - the 601XL has more of a bubble canopy
Mike Cooper
davelo
Post Take off checks
Unread post by davelo » Mon Jul 27, 2020 3:23 pm
IINM the Raven is more similar to the 601HD, certainly in terms of the wing. If you Google "601HD" the first few links that come up should perhaps give you a better idea of representative specs. To be honest I think the HD also had a bubble canopy though.
Dave Louw
"People demand freedom of speech as a compensation for the freedom of thought which they seldom use." - Soren Aabye Kierkegaard (1813-1855)
Faraway
Has liked: 12 times
Unread post by Faraway » Sun Aug 02, 2020 7:14 pm
Sunday evening bump
bluesmancoops
Unread post by bluesmancoops » Mon Aug 03, 2020 8:08 am
Thanks Faraway
Mike Cooper
Return to “Aircraft for Sale”
