Li Fe Rx batteries
SAS
Engine Started
Closest Airfield: GATEWAY INTERNATIONAL
Li Fe Rx batteries
Unread post by SAS » Mon Nov 05, 2012 11:43 am
I can't get all of my Li-Fe 6.6v Rx batteries to capacity (100%).They only go up to app 91% - 94% after they have been fully charged.Is that normal ?
clivem
Closest Airfield: howick
Re: Li Fe Rx batteries
Unread post by clivem » Mon Nov 05, 2012 12:53 pm
as i have said in the other thread - how are you measuring the % ??
if your using a battery tester that measures Voltage its not going to work well.
2S Life at fully charged will be 7,2V right off the charger, within seconds it will drop to its nominal 6,6V per pack (3,3V per cell) - 6,6V is around 91% of 7,2V so if you use a voltage based tester you will always see less than 100%
The only way to measure capacity is a discharge and recharge, then use Mah used and do the maths yourself to calculate % available.
Save a plane - Fly FUTABA !!!
http://www.cmchobbies.co.za
