use of genkem
cabeng
Closest Airfield: Rotorua -NZRO
use of genkem
Unread post by cabeng » Tue Mar 12, 2013 1:20 pm
Got a brilliant tip this weekend from Clive , cmchobbies Clive
we wee chatting about servo horn screws coming loose, I hate using locktite there as its a mission to loosen and easy to do damage
his advice was to use a dab of "Genkem" on top of the head once the screw has been fully tightened , it dries fairly hard but rubbery and will bot let the screw fall out , but easy to pick off when needed
Brilliant advice Clive =D> =D>
Clearly Weekends are made in china . They simply dont last !
Kleinmeid123
Re: use of genkem
Unread post by Kleinmeid123 » Thu Mar 14, 2013 8:56 pm
Great tip. I used cutex (the red one works the best :lol: ) Also fairly easy to unscrew when you need to.
cabeng
Re: use of genkem
Unread post by cabeng » Fri Mar 15, 2013 9:27 am
Kleinmeid123 wrote:Great tip. I used cutex (the red one works the best :lol: ) Also fairly easy to unscrew when you need to.
=D> =D> , good one too
Hennie vd Walt
Closest Airfield: Herderberg
Re: use of genkem
Unread post by Hennie vd Walt » Tue Aug 13, 2013 7:47 pm
Good one I'm going to do this ... =D> =D> =D>
Hennie vd Walt
0823603235
