Vaal dam airfields
Information regarding aviation friendly destinations and airfields.
JimmyZ
Engine Started
Closest Airfield: FAKT
Has liked: 11 times
Vaal dam airfields
Unread post by JimmyZ » Sat Feb 29, 2020 7:14 pm
Hi all.
I'm looking for airfields I can use in the Vaal dam area. I plan to do a scenic flight to the Vaal, and am looking for a place to land to stretch legs.
I can see Deneysville and "Vaal" airfields on the standard SA VFR map, but I've no idea what the condition is at either, or if they even still exist.
Also I'm wondering if there are any other airfields not on the map that I will be allowed to use. I can do tarmac, gravel and grass.
Any info would be appreciated.
Jimmy
Segg
Has liked: 208 times
Been liked: 44 times
Re: Vaal dam airfields
Unread post by Segg » Sat Feb 29, 2020 7:26 pm
Hi all.
Jimmy
The old Deneysville airfield no longer exists, the closest is Skydive on the Vaal's grass strip a KM or two down the road
Else Vereeniging isn't too far out, and Hiedelburg is also a possibility
rajarad
Straight and Level
Closest Airfield: FAVV
Unread post by rajarad » Sat Feb 29, 2020 9:46 pm
FAVV is close by, depending where you are flying from. Fuel also available. Deneysville also has a grass runway. Usually most weekends parachutes are active if weather holds.
Has liked: 638 times
Been liked: 567 times
Unread post by Ugly Duckling » Sat Feb 29, 2020 10:48 pm
Beware of the steel cable across the dam wall [-X
JimmyZ
Engine Started
Has liked: 11 times
Unread post by JimmyZ » Tue Mar 03, 2020 7:31 pm
Thanks all for the info.
I'm thinking I'm going to do the flight without a stop, but it's still good to know where all the spots are I can put down, should I need to.
Thanks for the heads-up, but I'm not going to fly that low over water 8-[
Segg
Unread post by Segg » Tue Mar 03, 2020 10:11 pm
The water levels are relatively low at the moment, with the shoreline quite well exposed at the moment I wouldn't bust much of a sweat if the donkey coughed :)
Just be careful of fishermen etc around the shoreline :lol:
These users liked the author Segg for the post:
JimmyZ
Andreb
Closest Airfield: Eagles Creek
Unread post by Andreb » Wed Apr 01, 2020 3:20 pm
You can stop over at Lekoa Lodge (East of Vaal) or Circus, coffee shop is within walking distance
JimmyZ
Engine Started
Has liked: 11 times
Unread post by JimmyZ » Fri Apr 03, 2020 8:14 am
Thanks. Lekoa Lodge seems like a nice option.
This lockdown is proving to be a spanner in the works for my Vaaldam flight :smt085
Return to “Destinations”
