450 Rooivalk project
- 10000 and still climbing
- Closest Airfield: Rand
- Has liked: 14 times
- Been liked: 108 times
Re: 450 Rooivalk project
It is starting to take shape now, hopefully the standard gear will now fit inside the fuse.
I also had to make the vertical fin thicker so the tail offset will fit.
I have to figure out how I will get the heli inside the fuse, I thought of making it split allong the red line, this will also be the batt access.
The line on the fin will have to be so the gearbox can be installed.
Still allot of sanding to do
T
T
Basic shaping done.A little fine sanding still remains.
Soon I will prime and start prepping for mold making.
T
T
Big desaster yesterday, I got home and somehow it seems the plug that was 90% ready somehow fell off the shelf and broke a few pieces off. I glued most back but all the finishing work needs to be re-done
- Too Tousand
- Has liked: 211 times
- Been liked: 17 times
Ai sorry about that one Theuns, really looking forward to seeing it come together.Theuns v V wrote:Big desaster yesterday, I got home and somehow it seems the plug that was 90% ready somehow fell off the shelf and broke a few pieces off. I glued most back but all the finishing work needs to be re-done![]()
Barry Wolmarans
Ah Barry , these things happen
All just little lessons in life we need to learn from, in this case - make sure you put the plug SECURELY on the shelff
A little more filling and sanding to be done before I can prep for mold making but almost looking like a rooivalk now.
T
T
- Frequent AvComer
- Closest Airfield: Ysterplaat
- Has liked: 0
- Been liked: 0
Wow lovely I would love one. Many years ago Herman Grobler went overseas and brought back a belt CP for me. My first 450 heli, he said he had a Rooivalk body for them I think it was vacuum formed anyways I never got around to getting it. I still fly the belt CP so to have a Rooivalk kit on it would just be awsome
I am sure I will be done with the mold in the next few weeks and then I can pop out fuses....stay tuned.
My first one will be in the all white UN scheme
T
T
The biggest hassle I see sofar is the offset tail drive unit. None available locally only from HK
I have seen one made, but that takes a longer than standard tail belt...no idea where to get it
I am very tempted to cheat on the prototype and just bring it out at the base of the fin.....but tell no-one
- Ooops forgot to turn the fuel back on!
- Closest Airfield: ORTambo
- Has liked: 260 times
- Been liked: 38 times
But won't t hit ground, seeing as it is a tail-dragger?
Nikon D500. 500mm f4, 24-120mm f4, 105mm f4 micro, 55mm f2.8 micro, Tamron 15-30mm f2.8
I looked at it, with a tail wheel long enough I don't think so . The real one does not sit to low anyway....it is just till I figure out the tail drive issue
When you photograf it oneday, just be "creative" with the angles you use
