Net care cripple two
Theuns v V
Has liked: 14 times
Been liked: 117 times
Unread post by Theuns v V » Fri Jan 22, 2016 8:21 pm
I was asked to do a comission build for someone to fot a Rapy 50 into one of my 222 fuses.
I hope to get the layups in tht molds tomorrow if the weather holds.
The cripple two will be the UT one without retracts.
I have been reading up allot and also spoke to Wonko, it seems on the Rappy the tailrotor box can simply be flipped 180 degrees to run on the port side of the fuse, this would be an interesting experiment as the 222's fin is located on the starbord side....
Pix to follow
T
Theuns v V
Has liked: 14 times
Re: Net care cripple two
Unread post by Theuns v V » Sun Feb 07, 2016 2:09 pm
Basic fuse pirmed ready for final sanding.
I will be making molds for the horsontal and vertical stabs as it would be lighter than the balsa /glassed ones I make now and speed up production.
I have also gone over to making vac formed clear windows instead of the solid ones
T
Theuns v V
Has liked: 14 times
Unread post by Theuns v V » Fri Feb 19, 2016 8:54 am
I have decided to make molds of the vertical and horisontal stabs as it will be faster and lighter to make composite units.
They will have spars and moundpoints internally.
Hopefully the first set will come out of the molds by tomorrow....
Theuns
Theuns v V
Has liked: 14 times
Unread post by Theuns v V » Sun Feb 21, 2016 1:47 pm
Prototype hollow composite stabs ready for priming
T
Theuns v V
Has liked: 14 times
Unread post by Theuns v V » Sun Feb 21, 2016 6:03 pm
Assembled horisontal stabs.
Theuns v V
Has liked: 14 times
Unread post by Theuns v V » Wed Feb 24, 2016 5:22 pm
Thjis particular cripple two was sold to another avcommer and it will not be completed as the Netcare helo, hopefully the new owner will post pix of his build :)
T
Notna123
Reaching altitude
Closest Airfield: Brakpan Benoni
Unread post by Notna123 » Fri Dec 06, 2019 11:41 pm
Evening
Do you still make and sell these fuselage kits. If so timeframe and pricing please.
Regards,
Anton
066 069 0567
Born to Fly, forced to work.
Theuns v V
Has liked: 14 times
Unread post by Theuns v V » Sun Dec 08, 2019 8:05 pm
Hi Anton.
Wassap me and I can.chat to.you.
Oh ate tree 742/to nine 28
Theuns
Return to “Scale Helicopters”
