Trex 450 EC135
chaos505
Taxiing to Clubhouse
Trex 450 EC135
Unread post by chaos505 » Wed Oct 03, 2018 3:06 pm
This is my 1st Scale heli.
However i didnt like the way it looked "stock".
so i masked and painted the panel lines and undercarriage for more details.
I do have a question though, whats the recommended pitch for scale?
Test hovered it and found the tail was not holding well and my stick was at ~85% throttle
wit out the body it was flying well
"Engines are the hearts of planes, but pilots are their souls"
skytrooper
Has liked: 22 times
Been liked: 26 times
Re: Trex 450 EC135
Unread post by skytrooper » Sat Oct 06, 2018 12:07 pm
450 Fenestron:
Ubluwulululululu....!
Theuns v V
Has liked: 14 times
Been liked: 124 times
Re: Trex 450 EC135
Unread post by Theuns v V » Wed Oct 10, 2018 6:41 am
I am by no means clued up on hellies but I also wonder if the standard tailrotor is perhaps "intefearing" with the scale tail. My logic tells me that the airflow from the tail might not be as smooth and therefore effective as it can be around the large area that is being blanketed by the scale tail.
I stand to be corrected though.
A tip for the future, if you want to highlight small detail like pannel lines, you could do a "pin wash" where you use artist acrylic ink mixed with water that you apply into the lined with a small fine tip brush. The ink should wick into the line and give it a nice look without having to mask the whole thing. If the ink goes where you dont want just wipe it off :)
chaos505
Re: Trex 450 EC135
Unread post by chaos505 » Wed Oct 10, 2018 10:01 am
:lol: thanks for the tip.
Was thinking the same thing about the tail.
It was holding fine when in pod & boom config, I have added bigger tail blades so need to test.
could be a combo of the added weight and "dirty air"
cakesmasher
Forgot to remove the chocks!
Closest Airfield: Jan Smuts
Re: Trex 450 EC135
Unread post by cakesmasher » Sun Jan 06, 2019 11:11 am
Hi
Did you see my post?
Price R4500. Still available.
https://www.avcom.co.za/phpBB3/viewtopi ... 1#p2000194
Wonko the Sane
Closest Airfield: Waterkloof
Has liked: 92 times
Been liked: 80 times
Re: Trex 450 EC135
Unread post by Wonko the Sane » Sun Jan 06, 2019 11:33 am
Very nice work there chaos! Yes, obstruction of airflow is the cause... bigger tail feathers will in all likelihood improve it but will not go away... going FBL will also help by reducing the drag from the paddles.
W
Andre Dethioux
RPL (MR)
chaos505
Re: Trex 450 EC135
Unread post by chaos505 » Sun Jan 06, 2019 8:52 pm
Thanks Wonko
Sadly i've put the heli back in pod and boom, and gave the body back to my friend.
Maybe will reinstall it when i get the align V2 EC.
I think this body was the V1 the front part is fixed so you have to connect the battery through the window
Return to “Scale Helicopters”
