Wanted - Anyone that can do Lexan/perspects LSA windscreens
Forum rules
No commercial adverts please (If your intended post is of a commercial nature, then please follow this link and read BEFORE you post : http://www.avcom.co.za/phpBB3/viewtopic.php?t=54617) .If you are advertising for a friend - the ad must contain the owners contact details. If you wish to advertise in the commercial section: - email ads@avcom.co.za for more information. Model Aircraft have their own section - any posted here will be deleted.
- Aircraft in Hangar
- Closest Airfield: FAPE
- Has liked: 0
- Been liked: 0
Hi all,
As life is about contacts, does anyone know or can recommend a person/company, that can redo a perspects windscreen for a LSA Aircraft. I cannot get a factory mould so will have to redo it manually...
Thoughts, suggestions, ideas?
- Forgot to remove the chocks!
- Has liked: 0
- Been liked: 0
Re: Wanted - Anyone that can do Lexan/perspects LSA windscreens
For what plane is it?
I may be able to help.
Manfred 0 eight three 76 four 59 three 5
- Frequent AvComer
- Closest Airfield: FAEL
- Has liked: 0
- Been liked: 11 times
There is a company in Cape Town that does this but I have no idea of the name of this company. Maybe the Cape Town boys can help here.
- Has liked: 0
- Been liked: 0
Thanks all, it is for a little JORA UA2. It is ideally supposed to be 2.7mm thickness.
Im based in PE, but can fly the aircraft where needed...
- Tree Tousand
- Has liked: 15 times
- Been liked: 12 times
Get hold of Jan Diener through SFC.
- Has liked: 0
- Been liked: 0
The Jora's windscreens are just flat sheets which you can cut out with a angle grinder.
You don't need to have them blown.
- Rolling
- Closest Airfield: Wingfield
- Has liked: 2 times
- Been liked: 1 time
If this is true, just go to your local Maizeys and ask for flat polycarbonate sheet. They can cut to size. Remove your old windscreen, which will also lay flat when removed, trace it on new sheet and if its complex cuts, do it with a electric jigsaw with a metal cutting blade (fine teeth). Drill holes (if riveted) with a modified drillbit (google this) and your set to reinstall. This worked with my J3 Cub clone.
As a side note, the 2 main types of windscreens are Acrylic and polycarbonate.
Polycarbonatehas trade names like Lexan in the USA and Palsun in South Africa. Polycarbonate is tough in terms of impact resistance. Will take quite a shot and only bend /deflect but will not easily shatter. Can be cold bent and fixed under tension. Cannot be heatformed to compound shapes. Also once its picks up scratches, one cannot really polish them out.
Acrylic Goes by trade names like Plexiglass or Perspex. Usually thicker than Polycarb. Can be heatformed to shapes - usually with a mold. Scratches can be ‘flatted’ out if deep or just polished if shallow. Is more brittle and thus more prone to shatter under impact.
So knowing what type of screen you require is step 1. If polycarb you can do everything yourself and fairly cheaply.
If its acrylic and you can track someone down who has a mold, price will be reasonable. If someone has to make you a mold and the screen, expect a pretty heavy bill.
Amat victoria curam
- See Helicopter in the distance
- Closest Airfield: faps
- Has liked: 33 times
- Been liked: 16 times
Dirk Uys does any windshieldsDirk.tromp wrote: ↑Tue Nov 19, 2019 11:52 amHi all,
TCA AND NTCA
He is in Potch
C210
Cirrus sailplane
Cirrus sailplane
