Any gyro homebuilders around?
Vertical Tango
Engine Cranking
Re: Any gyro homebuilders around?
Unread post by Vertical Tango » Tue Apr 04, 2017 3:48 pm
Leave the rotors on, a simple support system works well. This is what I did a while back when I had a Magni. No problem up to 120 Km/h.
nomie
Unread post by nomie » Tue Apr 04, 2017 3:53 pm
And I thought Magni rotors was one of the easiest to get on and off!
p.s. Magni also makes a single seater. http://www.magnigyro.co.za/model-m14.html
Not twitchy at all. Just loads of fun! I believe there might even be one for sale...
aircraft market .co.za -> Magni M18
Has liked: 63 times
Been liked: 349 times
Unread post by Bearcat » Tue Apr 04, 2017 4:06 pm
A.M. Terblanche TNT MK1 ZU-CDE at Parys Airfield FAPY
21 March 2015
nomie
Unread post by nomie » Tue Apr 04, 2017 4:26 pm
Autogyro also makes a naked version of the MTO-Sport, Called the MTOfree. I think you can buy a kit.
Theuns v V
Has liked: 9 times
Been liked: 52 times
Unread post by Theuns v V » Tue Apr 04, 2017 5:50 pm
That TNT Mk1 is what I had inmind, a kit will be to expensive "once off" I am not worries about scratch building.
T
Rotor kop
Closest Airfield: OR Thambo
Has liked: 35 times
Been liked: 11 times
Unread post by Rotor kop » Wed Apr 05, 2017 5:42 am
nomie wrote:
Theuns v V wrote:What I like about the benson is that it is a very small gyro and I am sure it could be made so that the rotors come off and it can be trailored instead of having to hanger it.
T
As far as I know you can remove just about any gyro's rotors in a reasonable time. Only the amount of bolts you have to remove varies. Some keep their alignment better than others though :?
Not sure why you would want to remove the rotors anyway? We stransport anything from R22 to Enstrom on trailers and don't remove anything. Just make sure you support the rotors correctly thats all :idea:
Rotor kop
Has liked: 35 times
Unread post by Rotor kop » Wed Apr 05, 2017 5:44 am
Vertical Tango wrote:Leave the rotors on, a simple support system works well. This is what I did a while back when I had a Magni. No problem up to 120 Km/h.
Only saw this post now :oops: That trailer is almost what i am talking aboutbut I would definitely use double axle only for a few reasons but mainly potholes and ride.
Theuns v V
Has liked: 9 times
Unread post by Theuns v V » Wed Apr 05, 2017 6:55 am
Just for simplicity to be able to store it in a garage :)
nomie
Unread post by nomie » Wed Apr 05, 2017 11:49 am
Rotor kop wrote:
T
Simply to minimize the stress on the rotors (Gyro rotors is a bit more floppy than helicopter rotors yes?). And to shorten the load so that it can fit on short trailers / in your garage.
Theuns v V
Has liked: 9 times
Unread post by Theuns v V » Wed Apr 05, 2017 12:14 pm
To store in a garage, exactly yes :)
Where do homebuildedr get rotors? Are there plases that make then and will sell them in pairs or are they made by builder?
T
Theuns v V
Has liked: 9 times
Unread post by Theuns v V » Wed Apr 05, 2017 12:34 pm
Here is what I am after to build, doesn't look to expensive, the fun factor seems very high and storage is no issue.
https://www.youtube.com/watch?v=MUEt1xcLuW8
Granted the vid might seem "GUNG HO" but still looks like a lekka gyro....
T
Closest Airfield: Ermelo
Been liked: 22 times
Unread post by Whirly » Wed Apr 05, 2017 1:15 pm
Do all gyros shake like that? :?
Theuns v V
Has liked: 9 times
Unread post by Theuns v V » Wed Apr 05, 2017 4:06 pm
You mean the oke is not chewing gum.... is is the vibration :lol: :lol:
I did see the vibration on the stik.
I saw another vid of this guy flying the gyro sideways....no idea how he does this :)
Theuns v V
Has liked: 9 times
Unread post by Theuns v V » Wed Apr 05, 2017 5:52 pm
Anyone have any contact detail for the owner/builder of that TNT Mk1 ?? [-o< [-o<
T
Braam Hechter
Tripped over wheel chock
Closest Airfield: Vereeniging
Unread post by Braam Hechter » Tue Apr 18, 2017 7:27 am
Good Day All.
I have been following this thread with interest.
Herewith a photo of what Johan von Ludwig from Wagtail is also assisting with. He is just helping the owner with the complete process, from modification application, design, manufacturing and then the test and proving flights.
Greetings and safe flying.
Braam
Return to “Gyro Chatter”
