Buying a polished turd
Frans Larkins
Mags On
Closest Airfield: Ngodwana
Unread post by Frans Larkins » Mon Aug 10, 2020 7:28 am
I purchased a NEU1509 motor on Avcom a year ago but never tested it as I was waiting for my Toko2 that I have ordered at Cloudbased Composites. Well the Toko arrived and when the motor was installed and I did the direction check, I heard something was wrong. When I opened the motor, you can clearly see the glue marks on the magnets, it cracked all over and had broken out in the front of the motor. You can also see the rust deposit on the rotor, indicating that this happened a while ago.
I feel like that blind kid on the move Dumb and Dumber who purchased a dead parakeet bird.
Maybe not a Avcom topic, but yes, I paid R2k for the motor if my memory serve me correct.
Ultimate 42%
Chipmunk
Stop Sign
Mini Ultra Stick
X1000 drone
Phantom 4 pro
Yak 54 42%
V900
X1 racer
Evo R racer
Dago Red Mustang
Toko2
nic weskus
Closest Airfield: st Helena bay
Has liked: 79 times
Been liked: 36 times
Re: Buying a polished turd
Unread post by nic weskus » Mon Aug 10, 2020 7:56 am
LEALDADE
nic weskus
Has liked: 79 times
Unread post by nic weskus » Mon Aug 10, 2020 8:03 am
Skande.
Name and shame him.
Have you confronted him yet???
It's magnets obviously were glued back up again.
That neo is a very high KV and about 1800W hotliner motor, and thus state -of -art.
NEU 1509 1.5d swings a17x17 carbon-cam prop. 200A esc
To send that motor back to overseas factory is going to cost upwards of R4k.
Have you link to advert?
Such a seller is a donderse skelm and should be sorted out.
These users liked the author nic weskus for the post:
Rotor kop
LEALDADE
MegaTesla
Forgot to remove the chocks!
Unread post by MegaTesla » Mon Aug 10, 2020 5:04 pm
In a Neu like this the 4 magnets are glued to the core and then wrapped with carbon fibre tow. Is the carbon tow still wrapped around the outside of the magnets?
Micro ducted fan crazy.
Frans Larkins
Mags On
Unread post by Frans Larkins » Mon Aug 10, 2020 6:40 pm
Hi. No. There is no carbon fibre toes on these magnets.
It was turning nicely by hand, but as soon as I opened the throttle, it made a click sound and was stuck. I thought in my stupidity, a washer or screw got pulled in by the magnet, and opened it, and then noticed that the screws on the side, 1mm allen cap screws, show signs of being opened. So I opened the motor and saw the magnets are cracked and broken, and the rust on the rotor shaft, and then I knew... this was not my fault.
Ultimate 42%
Chipmunk
Stop Sign
Mini Ultra Stick
X1000 drone
Phantom 4 pro
Yak 54 42%
V900
X1 racer
Evo R racer
Dago Red Mustang
Toko2
dries01
Closest Airfield: Bella bella
Unread post by dries01 » Mon Aug 10, 2020 8:15 pm
Naand Frans ja ek was ok al gevang op avcom
Frans jy kan die motor na Reid en Mitchell of LH Marthinusen toe neem hulle kan sulke eksie perfeksie jobs doen
nic weskus
Has liked: 79 times
Unread post by nic weskus » Mon Aug 10, 2020 10:07 pm
Frans, hoe kom jou elevator pushrod deur van voor die romp af? In die rudder af?
Moes jy modifikasies maak op die elevator? Ek sien daar is fibreglass insert/ arm of iets.
LEALDADE
Frans Larkins
Mags On
Unread post by Frans Larkins » Mon Aug 10, 2020 10:09 pm
Wow? Ek was is onbewus van dit. Ek sal LH more n lui gee. Ek het wel n epos na NEU gerig. Maar hulle het nog nie reageer nie. Maar ek sal verseker by LH hoor. Baie dankie v d raad.
Ultimate 42%
Chipmunk
Stop Sign
Mini Ultra Stick
X1000 drone
Phantom 4 pro
Yak 54 42%
V900
X1 racer
Evo R racer
Dago Red Mustang
Toko2
Frans Larkins
Mags On
Unread post by Frans Larkins » Mon Aug 10, 2020 10:14 pm
Hallo Nick. Die Toko kom met pre-installed pushrod wat 90 grade gebuig is en fit in n ronde socket op die elevator. Dis die eerste keer dat ek die konneksie sien en is onseker hoe sterk dit is?
Ultimate 42%
Chipmunk
Stop Sign
Mini Ultra Stick
X1000 drone
Phantom 4 pro
Yak 54 42%
V900
X1 racer
Evo R racer
Dago Red Mustang
Toko2
nic weskus
Has liked: 79 times
Unread post by nic weskus » Mon Aug 10, 2020 10:20 pm
Dis die eerste keer dat ek so iets sien.
Die GP resin is net aan die outer skin vasgesit. Nie met die control arm-pen deur die elevator na die ander skin nie.( soos met jou ailerons)
Daai ding gaan losskeur en teen joú beplande spoed baie hartseer maak.
Jy gaan ook baie play optel later van die vibrasies.
LEALDADE
nic weskus
Has liked: 79 times
Unread post by nic weskus » Mon Aug 10, 2020 10:26 pm
Dis die eerste keer dat ek so iets sien. 'n gat gemould. Geen verstellings moontlik. Geen control arm deur altwee skins ingesit nie.
Die GP resin is net aan die outer skin vasgesit. Nie met die control arm deur die elevator na die ander skin nie.( soos met jou ailerons)
Ek neem aan daai geel strepe se kante gaan ook skerper afgefinish word?
Hoe gaan jy met daai bestaande "control arm" enige fyn verstellings kan maak?
Want jou rudder servo se cover is mos teen daai tyd al toegemaak?
LEALDADE
Frans Larkins
Mags On
Unread post by Frans Larkins » Mon Aug 10, 2020 10:44 pm
Nic om eerlik te wees, die Baudis wat jy op avcom gekoop het was 1000 keer beter afgewerk. Alles met die TOKO loop skeef? Ek het n jaar lank gewag vir hom, sy afwerking is pateties en ek is nou erg bekommerd oor daai elevator koppelstuk.
Die gat in die stert moet blykbaar met Vinal toegeplak word volgens Craig. Die is n splinternuwe composit vliegtuig van Cloudbase Composites. Maar ek is erg omgekrap. Nou koop ek nog n motor ook wat stukkend is en my ESC pas nie in die fuzz nie.
Maar die verf werk is baie swak, en ek wag nou nog vir n manual om die CG te kry. Maar ek sal nie weer n vliegtuig koop by Cloudbase nie...
Ultimate 42%
Chipmunk
Stop Sign
Mini Ultra Stick
X1000 drone
Phantom 4 pro
Yak 54 42%
V900
X1 racer
Evo R racer
Dago Red Mustang
Toko2
nic weskus
Has liked: 79 times
Unread post by nic weskus » Tue Aug 11, 2020 3:39 pm
Frans,
Met respek gesê, daai fuse is baie beperk en nou/laag júís kritiek omrede dit 'n hotliner is.
Als moet perfek pas. Én jy moet sorg vir airflow!
Want jy wil verhoed om gewigte te gebruik om cg te kry. So jou rx, esc se gewig én sy plek vir lugvloei, motor gewig, bty posisie ens móét inskakel bymekaar.
Anders is jou voorland balancing-weights.
Daai motor spin teen 60 000rpm.
Met gearing af ek dink 6.7:1 na sy groot hotliner prop.
Jy kan miskien die esc-cooling fins se heatshrinks oopsny en hul na buite mount op fuse vir spasie.
Watse bty? Square of lank of in series?
LEALDADE
skytrooper
Has liked: 13 times
Been liked: 23 times
Unread post by skytrooper » Tue Aug 11, 2020 6:24 pm
Ek't 'n shongololo, ook van Craig, my idee was om die motor extern te mount, beste vir cooling. (nie seker of ek hom gaan klaar maak nie) (fondse #-o )
Ubluwulululululu....!
Theuns v V
Been liked: 218 times
Unread post by Theuns v V » Wed Aug 12, 2020 6:50 am
"pollished turd" ....and here I was told one CAN'T shine shyte :lol:
Return to “General Model Aircraft Chatter”
