Plettenberg Bay Cloudbreak
Hop Harrigan
Re: Plettenberg Bay Cloudbreak
Unread post by Hop Harrigan » Sun Apr 17, 2016 4:48 pm
"...comment just below the PLAN view"
...apologies for quality of the attachment...coming off iPhone
kleyn
Tripped over wheel chock
Unread post by kleyn » Sun Apr 17, 2016 4:54 pm
If you look at the Jeppesen plate it all become clear. There is no ring on the Jeppesen plate but only the note that specify that the initial approach altitude is 6300ft or higher MSA and to descend in the hold to 3500ft.
Jayson v Schalkwyk
Closest Airfield: Himeville
Been liked: 14 times
Unread post by Jayson v Schalkwyk » Sun Apr 17, 2016 4:58 pm
Hop Harrigan wrote:Ok, this might clear it up? Just pulled the Jepp plate (attached). Check the comment just below the lab view..."Initial approach altitude 6300' or higher MSA. Descend in holding to 3500'".
Strange that CAA/ATNS don't include this.
Check note 1 on the CAA AIP... It does say initial altitude of 6300 of higher MSA. It is assumed you will follow the standard procedure of flying the sector entry and then descend in the hold to 3500.
Jeppesen, makes using the plates easier by applying some of their own "data" and design layout. The briefing strip is just one such example. When airfields are close to terrain they will publish the plate with different shades of brown indicating the height of terrain, aiding situational awareness. They will also translate publish state minima in to a useable format i.e., taking the OCH and publishing a DA or MDA instead.
This is turning into a useful discussion. Well done guys.
Jayson van Schalkwyk
Hop Harrigan
Unread post by Hop Harrigan » Sun Apr 17, 2016 5:50 pm
Pic attach retried...
Hop Harrigan
Unread post by Hop Harrigan » Sun Apr 17, 2016 5:51 pm
…now the flipping' thing comes out sideways…grrrrrr
hatman
Unread post by hatman » Tue Apr 19, 2016 9:25 am
With many legal approaches into Plet in a bus jet we will descend vmc till top of cloud and then enter pattern for the approach. The whole reason for the cloud break is to keep you safe from the terrain. If it is clear to whatever level above the cloud you will be able to see any obstacles. The only condition is that you are established in the pattern at whatever level before going into the cloud. if the cloud is higher than the MSA then stick to the whole procedure.
apilot
Unread post by apilot » Sun Aug 21, 2016 7:15 pm
Thank you, hatman.
It's called a VMC descent.
AOYB
Unread post by AOYB » Mon Aug 22, 2016 7:17 am
There are lots of opinions, but very few references, so let me add a few.
SACARS 91.06.34 wrote: (1) When an instrument approach to, or instrument departure from, an aerodrome is necessary, the PIC of an aircraft shall use the instrument approach and departure procedure as published by the Director in the AIC, IAIP, IAIP Supplement or NOTAM or otherwise approved by the Director.
(2) No person flying an aircraft may execute, or endeavour to execute an instrument approach or instrument departure at an aerodrome unless—
(b)
the flight is conducted in accordance with procedures for instrument approach or instrument departure authorised by the Director for the specific aerodrome and manoeuvre to be executed;
91.07.15 wrote: (1) The owner or operator of an aircraft shall ensure that the instrument approach and departure procedures, established by the appropriate authority of the State in which the aerodrome to be used, is located, are used.
(2) Notwithstanding the provisions prescribed in sub-regulation (1), a PIC may accept an air traffic control clearance to deviate from a published approach or departure route: Provided that—
(a)obstacle clearance criteria are observed and full account is taken of the operating conditions; and
(b)the final approach is flown visually
So...You can deviate from the approach as published, but only if you can visually maintain the obstacle clearance. This then leads us into visual and VMC approaches. Two of the most misunderstood and misquoted items.
SACARS part 1 wrote:“visual approach” means an approach by an IFR flight when either part or all of an instrument approach procedure is not completed and the approach is executed with visual reference to the terrain
A VMC approach is not defined in the CARS, but it is in the AIP.
[quote="SA AIP"1.5.2.1"]A VMC Approach enables the pilot to descend below the initial approach altitude while maintaining VMC.[/quote]
The requirements for each and what they offer are slightly different. It is important to note that both allow the aircraft to maintain operation under IFR.
Sources for the following: SA AIP and SA Air Traffic Services section 2
Visual approach:
Seperation between aircraft is done by ATC.
Aircraft is within 25nm of aerodrome
Pilot can maintain own seperation from terrain.
Pilot will remain inside controlled airspace
Reasonable assurance that a visual approach and landing can be completed
Reported ceiling is above initial approach altitude.
VMC approach
Own traffic separation (traffic separation minima can therefore be reduced)
VMC (so basically VFR guidelines for visibility and distance from cloud)
Visual contact with the aerodrome
Since it is not mentioned, the pilot may be outside controlled airspace at times
Both are still IFR. It is also worth noting that a visual approach does not require you to have the field in sight, just that you must maintain visual reference to terrain.
So, in summary. Fly the approach as charted. Unless, you can satisfy the requirements above, and then you may omit portions of the approach in order to do a VMC or a visual approach.
As apilot mentioned, it will be a VMC approach into Plett.
I am the last Cylon...
SandPiper
Unread post by SandPiper » Sat Aug 27, 2016 10:20 am
Ja...but....
vmc and visual apptoaches are typically flown after breaking cloud.
This scenario is exactly the opposite.
I agree with hatman, but to pick the flypoo from the pepper, Brand is correct.
Ok, now I am confused. :roll:
Globemaster
Unread post by Globemaster » Fri Sep 16, 2016 12:26 am
I see a two fold reason for the notes:
Firstly the initial approach altitude or higher MSA is to ensure terrain clearance during your initial descent to the NDB.
Secondly the descent in the hold enables you to establish drift correction by the time you go down below 3500' (changing winds as you pass through different levels).
You have to assume worst case senario that the aircraft only has an ADF as this is the minimum nav aid required for the approach(no GPS for tracks).
Sticking to the approach ensures protection from the hard stuff.
All systems are go!
Upthere
Unread post by Upthere » Sat Sep 17, 2016 7:17 am
Having done plenty oversights with a SACAA TSO in the back of the simulator I can remember one of the questions asked.
Is it legal? Yes...
Is it the clever thing to do? No...
Next time you arrive at the airfield, the weather conditions might be slightly different and you will try and push to get in again. A lot of the accidents that have happend with customized approaches indicated that the pilot(s) have done it their way many times before.
'Slim vang sy baas'.
Fly, fly, fly, fly...
Hop Harrigan
Unread post by Hop Harrigan » Tue Sep 20, 2016 11:10 am
Gents,
So are we agreed? Even with 5000' of blue sky above a solid cloud layer, on arrival at Plet it is legally required that one enter and descend in the hold from 8000' down to the start of the approach at 3500'.
That takes me two holds (at -500'/min in order to preserve my pax eardrums) and adds about 8 minutes to the approach.
I do notice that a particular airline serving Plet descends on the way in to 3500'...but they may be using the RNav approach they've had approved.
Is there any possibility those nice airline guys might publish their approach for everyone to use?
Hop
yak55
Unread post by yak55 » Wed Sep 21, 2016 10:07 am
Flying the full procedure when IMC is legally correct and prudent.However when you can descend to 3500 on top it is acceptable to do so.
I regularly fly this approach and always descend to cloud top own terrain clearance even when still controlled by George.
Hop Harrigan
Unread post by Hop Harrigan » Wed Sep 21, 2016 9:23 pm
Hi yak55,
Not sure if you've read the posts above, but there seem to be differing opinions on whether the visual descent is strictly legal or not.
Be nice if we could get a definitive answer on this
Hop
P2T2
Forgot to remove the chocks!
Unread post by P2T2 » Fri Sep 23, 2016 6:04 pm
Nothing illegal about a visual decent in IFR below MSA. IFR in IMC is a different ball game. I don't see anything wrong with descending to 3500' or a higher cloud base in this instance before commencing the approach. Assuming you are visual up until that point.
