Correct way to fly the Procedure Turn?
Hop Harrigan
Re: Correct way to fly the Procedure Turn?
Unread post by Hop Harrigan » Fri Sep 30, 2016 9:14 pm
Hi jalopy,
Sounds like solid advice...clearly there is a major advantage to using the time on the outbound from the VOR to sort out the required wind correction, which can't be done if one has already executed the 45 deg turn.
Many thanks all!'
Hop
