What format to import a route into G1000H
Has liked: 105 times
Been liked: 93 times
Unread post by Bell 407 » Mon May 15, 2017 12:15 pm
Afternoon All,
Some quick assistance would be appreciated. I need to get a route into a B407 G1000H. I am using Basecamp to do the waypoint management on.
However, when I save the .gpx file to the memory card and plug it into the machine, it says "no flight plans listed".
Is there a different format to export from Basecamp for the G1000H to read?
Any help would be appreciated.
Has liked: 15 times
Been liked: 296 times
Re: What format to import a route into G1000H
Unread post by cage » Tue May 16, 2017 10:04 am
Bell 407 wrote:Afternoon All,
Doesn't the G1000 require a properly exported file with a .fpl extension?
I believe this is an XML file and your planning software needs to support the G1000.
Unread post by Bell 407 » Tue May 16, 2017 10:47 am
Thanks Cage, will look into the .fpl extension issue.
avjhb
Mags On
Unread post by avjhb » Wed Jun 07, 2017 6:30 am
I used to be indecisive but now I’m not so sure..
