Airdrome Aeroplanes - WW1 Replicas
RudiGreyling
Closest Airfield: The Coves
Unread post by RudiGreyling » Fri Jan 12, 2018 2:45 pm
Improving the Aileron and Elevator controls:
I did not like the aluminum bellcrank sandwich rotating on a bolt, which the plans specified so I asked a friend for help and he laser cut and welded a new belcrank which can now rotate on a brass bush instead. Thank you Mr. Alan!
Here it is installed again, with a Delrin spacer to stop it from potential going over center.
Then I could install the control stick and connect the elevator push rod.
Once again I did not like one long elevator push rod as the plans specify because it flexes, so once again research and manufacturing an improvement creating a bellcrank aft fuselage midway to eliminate flex.
Once again my friend Mr. Alan came to the help and turned a couple of new bushes for me to make the push rod modification
Here is a tempory assembly of the pushrod bell crank
Then, most of these airplanes come in nose heavy, so then people add weight to the back. If I had to add weight I was going to make it functional. So I balanced out the Elevator with adding just enough metal rods inside the front leading edge, to compensate for the mass in the rear and it balances perfect. This will mean lighter elevator controls
These rods will be fiberglassed into place with a couple of wraps of cloth where the masking tape is currently.
Last edited by RudiGreyling on Thu Jan 25, 2018 10:24 am, edited 3 times in total.
Amateur Kit Builder
RudiGreyling
Unread post by RudiGreyling » Fri Jan 12, 2018 2:48 pm
Building a Seat:
Start by marking seat frame gussets in raw sheet to attache the seat to the airframe.
Cut and deburred and pilot drilled. One of them are bent to shape.
Cut and bend some tubing and fish mouth the joins. Lots of fitting and tweaking to get it to this stage.
Drill and fit the seat frame into the fuselage. Using straps to hold everything together.
Drill the seat platform
Rivet everything together
Take the airplane for a ride! Airplane noises mandotory!
Amateur Kit Builder
RudiGreyling
Unread post by RudiGreyling » Fri Jan 12, 2018 2:50 pm
Build floor pans and rudder pedals:
Start by marking out the parts in raw sheet.
Cut and debur the parts
Here the floor pans are riveted into the fuselage and I made 3 positions to make the rudder pedals adjustable.
Assemble and drill the rudder pedals together. Here you can see how they fit together. It is basically a lightweight aluminum sandwich that makes it strong.
Rivet them. That big hole is to fit the rudder cable attach bolt and the sandwich is riveted together.
Fit the rudder pedal in the center position and attach the rudder cables. The rubber bands are just temporary until I can buy some springs.
Amateur Kit Builder
GeraldNagel
Unread post by GeraldNagel » Fri Jan 12, 2018 2:50 pm
FANTASTIC =D> =D> =D> =D> =D>
RudiGreyling
Unread post by RudiGreyling » Fri Jan 12, 2018 2:54 pm
Building a firewall:
Start the firewall by planning the cowl nose cone fitment because the firewall matches that exact shape.
Mark out the firewall in raw sheet and cut it
Drill the firewall to the front of the fuselage
Mark out the cowl breather/air bypass holes on the sides
Start to cut and debur the breather holes
Cut cowl attachment strips from flat aluminum, bend it 90 degrees and flute them to the contour of the firewall
Backrivet the cowl attachment strips all around the firewall.
Cut and do the same for the instrument panel.
Amateur Kit Builder
RudiGreyling
Unread post by RudiGreyling » Fri Jan 12, 2018 2:59 pm
Modify the Engine and Build a FW mock up:
I bought a low hour HKS engine. It is a true aviation engine based on modern motorcycle technology. Its a 60HP, 4 valve per cylinder, 4 stroke, boxer engine with integrated gearbox.
This is how it came out the box.
The first task was to modify and put the carbs on top of the engine (its an option for this engine) to make the engine more compact for fitment and less weight that far out on the nose.
The second task was to modify and change the gearbox from the up position to the down position so the engine sits higher in the cowl. This give me more space in the cowl below the engine to fit the exhaust and the oil cooler.
Taking off the gearbox cover, inspecting as I go, this engine is in very good condition. Wonders of modern synthetic oils.
Taking off the front engine cover and flipping everthing 180 degrees to re-assemble.
I decided to re-use the engine mounting plate that came with the engine and then I planned the thrust line offset on a piece of plywood. I am using 3 degrees to the left, and the firewall has 3 degrees down built in with reference to the wing and tail cord line.
Fitting the engine mount plate on threaded rod to adjust the height perfectly.
Now I hoisted the engine into position and I created a mock firewall at the correct distance. Here you can also see the engine with the Gearbox in the Down position. Notice also the red line the 3-degree engine thrust line offset.
Another view from the side. I will now use this setup to manufacture an engine mount to fit the firewall.
Amateur Kit Builder
Euro Flyer
Closest Airfield: Country side grass strip
Has liked: 21 times
Unread post by Euro Flyer » Fri Jan 12, 2018 4:08 pm
Outstanding, loving this build as much (maybe more than) your RV one's ... perhaps as you say it's because there's a lot more 'real' building work involved.
EF
Pete
Has liked: 19 times
Been liked: 24 times
Unread post by Pete » Fri Jan 12, 2018 10:23 pm
Awesome Rudi! =D> =D>
Thought it was quiet and you were having a nice holiday.. but you have been whittling away very nicely, cant wait for the next pics on the progress :smt023
PJL
Has liked: 16 times
Unread post by PJL » Sat Jan 13, 2018 8:29 am
Rudi, I love the precision and attention to detail that you put into your work, as an engineer I also admire the way you tackle upgrading parts where you deem necessary!! This displays workmanship of the highest order, well done mate I am so impressed!!
PJL
― Leonardo da Vinci
ColdFingers
Closest Airfield: FADU Walkersons
Unread post by ColdFingers » Sat Jan 13, 2018 9:06 am
Thanks rudi for the updates. Amazing work. I enjoy your thinking and design modification.
Andy Mills
I'm supposed to respect my elders, but its getting harder and harder for me to find one now.
Has liked: 77 times
Been liked: 60 times
Unread post by richard C » Tue Jan 16, 2018 9:03 am
=D> =D> =D>
I am floored ! Beautiful job !!!
Grant all equity and dignity.
pietmeyer
Unread post by pietmeyer » Thu Jan 18, 2018 4:53 am
I am amazed at this build. It is unbelievable what you can do. I tried to build a circuit board using two aa batteries, wire and a flashlight light bulb for our daughters grade 4 science project. It envolved a small piece of wood, copper wire and a glue gun. I failed misserably. I can do some science but if i touch any tools ( normally a screwdriver or hammer), my wife calls the handyman as well as the fire brigade and hands me a box of bandaids... all in that order
I love watching this build. I would love to be just an assistant to such a project one day when i have time. Truly amazing Rudi. =D> =D> =D> =D> =D> =D>
ZU-DUU Jabi J400 (FAWB)
Multirotordronepilot
Has liked: 27 times
Been liked: 50 times
Unread post by Multirotordronepilot » Thu Jan 18, 2018 6:40 am
World class absolutely world class =D> =D> =D>
Trevor
Defense Contractor/Test Pilot
Commercial pilot,Instructor
Responsible Person Aircraft
TopRC HawkerHunter
JetLegend ViperJet
BVM F80 ShootingStar
1/3 J3 Cub
ZS-VVR
Closest Airfield: FAPX
Has liked: 12 times
Been liked: 54 times
Unread post by Chalkie » Wed Jan 24, 2018 5:48 pm
RudiGreyling wrote:Modify the Engine and Build a FW mock up:
Hi Rudi, I have been enjoying looking at this build of yours and noticed that your carb mod will move the engine CofG forward, so I guess the space saved behind the engine for air filters etc, would result in you being able to move the engine back slightly. I guess the saving will be small. The second note is the long inlets could be prone to icing (not carb ice but similar consequences.) My advice would be to use hot oil to warm the inlet manifolds and cool the oil at the same time. This could save the weight of an oil cooler.
Two ways of doing this: 1. Weld a metal jacket around the inlet pipes and port hot oil through them or 2. Wrap copper pipes around the inlet pipes and silver solder them in place. Copper work hardens, so the ends would need to be supported, but it can be done.
Enjoy the build and fly safe.
Rule #2 Hurry up Slowly.
RudiGreyling
Unread post by RudiGreyling » Thu Jan 25, 2018 10:21 am
<SNIP>
Hi Chalkie, THANK YOU, well worth the consideration! Lucky this 'modification' is an approved and actually the prefered layout from the engine manufacturer so there are lots of real-world experience and hours with it. This specific 2nd hand engine came out of a Savanah Oribi that had the carb layout behind. What I also did not say, is that the dry sump oil tank can now fit between the intake manifolds behind the engine on the firewall, whereas before it was blocked by the airfilters and the whole engine would have to be moved 150mm forwards. So on the photos, it does not look like I gained anything, but taking the future oil tank and engine mount arrangement into consideration I have :D
HKS Manufacturer Standard Layout with carbs on top and Exhaust option behind. My Exhaust will go below
Amateur Kit Builder
Return to “Airdrome Aeroplanes”
