Airdrome Aeroplanes - WW1 Replicas
ColdFingers
Closest Airfield: FADU Walkersons
Unread post by ColdFingers » Wed Jun 07, 2017 3:17 pm
Rudi,
A question, if I may. Does the annealing process not weaken the structural integrity of the structure?
Andy Mills
I'm supposed to respect my elders, but its getting harder and harder for me to find one now.
RudiGreyling
Closest Airfield: The Coves
Unread post by RudiGreyling » Wed Jun 07, 2017 4:01 pm
ColdFingers wrote:Rudi,
No not of the structure, but the pipe at that specific point of annealing has a lower strength that needs to be taken into account for the whole structure. Make sense?
Amateur Kit Builder
ppakotze
Unread post by ppakotze » Fri Jun 09, 2017 9:28 am
Rudi foto vir jou soortgelyke konstruksie.
RudiGreyling
Unread post by RudiGreyling » Fri Jun 09, 2017 10:48 am
ppakotze wrote:Rudi foto vir jou soortgelyke konstruksie.
That looks interesting what is it...i see it has an undercamber wing. The Original Fokker E-III also had an undercamber wing, but the replica i am building has a modern Clark Y profile.
Amateur Kit Builder
Been liked: 492 times
Unread post by Bearcat » Fri Jun 09, 2017 11:06 am
Looks like a Bleriot
RudiGreyling
Unread post by RudiGreyling » Fri Jun 09, 2017 12:14 pm
Very Nice, I see Airdrome Aeroplanes have 2 versions of the Bleriot as well. 75% scale and 100%scale = http://www.airdromeaeroplanes.com/bleriot.html
Amateur Kit Builder
Tomcat1
Closest Airfield: Silverton
Has liked: 19 times
Been liked: 59 times
Unread post by Tomcat1 » Fri Jun 09, 2017 12:15 pm
Tomcat1
Has liked: 19 times
That is a Bleriot guys :wink:
RudiGreyling
Unread post by RudiGreyling » Fri Jun 09, 2017 3:07 pm
Ok this weekend I am ready to tackle the Fuselage sides. Below is the drawing, you need 2 mirror images of each other, Left and Right. (Once again I deleted the dimensions to protect Kit Manufacturer IP). Same process as the Elevator, built flat on a table. This time around I need to learn new skills again...fishmouthing or coping the tubes to fit each other... More on that Monday enjoy the weekend.
Amateur Kit Builder
ppakotze
Unread post by ppakotze » Sat Jun 10, 2017 10:44 am
Jip photo taken at Aviodrone. Die museum is vol Fokkers en ook vliegtuie maar ek het nie 'n Eindecker gesien nie.
Groete P
Cedric Snr
Unread post by Cedric Snr » Mon Jun 12, 2017 9:04 am
Hallo Rudi,
here is a very inexpensive design you can have made at any engineering shop of a Fishmouthing/Notching tool that works of a normal drill.
Cedric Strydom
0763157134
cedric.strydom@live.co.za
RudiGreyling
Unread post by RudiGreyling » Mon Jun 12, 2017 10:06 am
Cedric Snr wrote:Hallo Rudi,
Hi Cedric, thank you very cool, I think that tool will work great on Steel! Lucky Aluminium is very soft so a quick trace and then belt sander and deburring bench grinder did the trick for me. I will post more on that later. Also most tube joins on my kit are different diameters so you need to account for a center offset so that the gusset will rivet flush against both tubes. More later today when i update the weeks progress. Kind Regards, Rudi
Amateur Kit Builder
RudiGreyling
Week 3: Start on the Fuselage Sides
Unread post by RudiGreyling » Mon Jun 12, 2017 2:30 pm
Week 3: Start on the Fuselage Sides [14 Hours]
Good afternoon Av8tors,
So I started on the fuselage sides, did 14 hours on the fuse so far, they say it should take 40H, we will see where I end up.
Once again I am posting a little more detail just because some techniques are new to me, and you might want to know.
First cut and create over sleeves, these are reinforcement points later for the Landing Gear and Cabines with Flying Wires attachments.
Bend the bottom longeron, and insert the oversleeves:
Tube Coping: You can eyeball the coping and then make it fit by trial and error, but i don't want to practice make a mistake and screw up and then scrap material...so I found this little Tube Coping Calculator: http://www.metalgeek.com/static/cope.pcgi . Add your tube dimensions and then you print it, cut it out, wrap around your tube and trace it. Most of the tubes need offsets since the diameters between the cut tube and parent tube is not the same, you want the tube to lay flat next to each other so that when you rivet the gusset on, the gusset sits flat.
This is my Coping and Deburing machines, a Belt sander and a bench grinder with deburing wheels.
By working the Tube on the belt sander rounding and at an angle as shown you create a perfect fish mouth in 1 minute.
Result after belt sanding
Run it on the bench grinder deburring wheel for 1 minute, then you have a perfect fish mouth in 2 minutes flat.
Insert the vertical supports, coped both ends, lifted slightly with spacers to align the the top of the outer longeron tubes.
Insert the cross bracing
Next the the tedious task to create Gussets from rough cut Alu Stock. First the original stock supplied
Cut to shape
Match Drilled to the fuselage and deburred, watch your spacing and edge distances (1.5 hole diameters left to the edge)
The Front fuselage Side, all the gussets riveted in place with the exception of the cross bracing, they are just clecko'ed in for now, since I will need to remove them for access when you fit the horizontal supports. Notice the Machine plug and bolt on the front, this is the top engine mounting bolt. I also drilled small pilot holes where the wing carry through spars will attach to the fuselage so that I can easily enlarge them later when the fuse is built.
I think this took a bit long, since there was lot of figuring out and new techniques to learn. This week I will add the rear longerons and bend them to join at the tail, then make a mirror image for the other side fuselage.
Till Next Week,
Groete
Amateur Kit Builder
Pete
Has liked: 28 times
Been liked: 34 times
Unread post by Pete » Tue Jun 13, 2017 7:04 am
Magnificent Rudi and thank you for your detailed presentation, we are all learning new things here! =D> :D
Has liked: 133 times
Been liked: 49 times
Unread post by Fransw » Tue Jun 13, 2017 12:36 pm
Pete wrote:Magnificent Rudi and thank you for your detailed presentation, we are all learning new things here! =D> :D
Yes, thank you!
Its good to see the master at work!
Return to “Airdrome Aeroplanes”
