The Hybrid Hinge
We are an online hobby store providing customers with extra mile service on a safe and secure website. We are based in Johannesburg and ship country wide. Put us to the test! https://www.rc-king.co.za
Moderator: RC-King
RC-King
Commercial Supporter
The Hybrid Hinge
Unread post by RC-King » Fri Aug 02, 2019 10:29 am
For all the "build your own plane" fanatics, we now have hybrid hinges that we are so excited about:
The Hybrid Hinge is made from polyurethane film which has been precision laser cut. The hinge has its own key cut directly on both sides of the hinge ensuring that the hinge is glued firmly into the trailing edge and control surface. If the hinge is coming out, so is a piece of the trailing edge or control surface. In addition a pin hole is laser cut into the hinge to help the builder center the hinge during the installation and gluing process.
Hinges can be glued using Thin Super Glue, Cold Glue and Epoxy.
The Hybrid hinge has a breaking force of 17kg when weight tested, in comparison to regular cyno hinges that tear at around the 3kg mark.
For electric and nitro planes up 20cc Max.
https://www.rc-king.co.za/aircraft-acce ... es-15.html
Return to “RC King”
