Power checks
Been liked: 108 times
Power checks
Unread post by cage » Fri Jan 25, 2019 6:51 am
Found the app by Standard Aero - SA Power Check.
It's for Android and Ios.
Use the calculator, pick the aircraft type and punch in the values.
Easy.
YoungPilot
Hee Hee I'm Flying
Re: Power checks
Unread post by YoungPilot » Mon Jan 28, 2019 10:54 am
The only aircraft that I fly with Allison engines and the app doesn't have it #-o Looks good though.
If you are depressed, you are living in the past.
If you are anxious, you are living in the future.
If you are at peace, you are living in the present.
- Lao Tzu
Re: Power checks
Unread post by cage » Mon Jan 28, 2019 11:26 am
Mail them, If you ask nicely they may just add it for you.
Which model is it btw? 105?
YoungPilot
Hee Hee I'm Flying
Re: Power checks
Unread post by YoungPilot » Mon Jan 28, 2019 11:34 am
105 LS yeah. Will need to get for the C28C and C30P 8-[
- Lao Tzu
Return to “Rotor Wing”
