So what are the numbers?
hugo_visser
Been liked: 33 times
Re: So what are the numbers?
Unread post by hugo_visser » Fri Feb 15, 2019 8:36 am
When balancing the tail rotors we end up with out of balance of 0.02 gram, 0.07 gram.
Hugo.
Been liked: 179 times
Unread post by cage » Fri Feb 15, 2019 9:35 am
Bell 407 wrote:
Fri Feb 15, 2019 8:18 am
Wonko,
Here is a run of 3 pictures of a B222 with big flappy blades passing by at speed. You can see the very pronounced difference in AoA between the advancing and retreating blades.
It is also exaggerated by washout which makes the main section look more severe than the outer portion.
Unread post by cage » Fri Feb 15, 2019 9:36 am
Hugo.
I think you're broadcasting on the wrong frequency Hugo :lol:
Chopper One
Unread post by Chopper One » Mon Feb 18, 2019 4:51 pm
I agree to all of the above from high AoA to washout, but as previously said I wonder if the white & red paint scheme on top of the blades creates an optical illusion? Here is the video I promised to upload.
In the shadow of the Blade!
Wonko the Sane
Closest Airfield: Waterkloof
Has liked: 63 times
Been liked: 55 times
Unread post by Wonko the Sane » Tue Feb 26, 2019 6:52 pm
W
Andre Dethioux
RPL (MR)
Return to “Rotor Wing”
