Best light turbine hours for CPL?
Has liked: 421 times
Been liked: 174 times
Unread post by Fransw » Sat Mar 23, 2019 12:42 pm
Asking for a friend..
What is the best light turbine hours to have for a CPL-H and why? 206jr/206lr/R66/Airbus/bell 505/etc....
Thanks and muchas gracias! :D
Rotor kop
Closest Airfield: OR Thambo
Has liked: 847 times
Been liked: 104 times
Re: Best light turbine hours for CPL?
Unread post by Rotor kop » Sat Mar 23, 2019 6:36 pm
What about a helicycle? Much more difficult to start than any other (complicated) and not to mention cheap? I know the jealous okes will whine its not a "real" turbine....i beg to differ, it is exactly the same and sounds the same and burns the same fuel :)
I am referring to hour building obviously. There have been a few guys in the US that did 1000 hours helicycle and went on to fly big things 8)
Unread post by Fransw » Sat Mar 23, 2019 6:45 pm
So you think it doesn't matter on what turbine machine..
But say for example this guy has an opportunity to do ±300 hours on a turbine machine, after his Cpl. Wouldn't it be better to do it on a more commonly used machine for future job opportunities?
Rotor kop
Unread post by Rotor kop » Sat Mar 23, 2019 6:50 pm
Yes sure it would. But if you needed the hours to get the turbine hours up i would use helisukkel. No difference when going for ATPL, a cesna 152 has been very popular in getting a lot of those hours. :wink:
Unread post by Fransw » Sat Mar 23, 2019 7:18 pm
Thanks RK!
My next question: Which candidate do you think is more employable: The one with 1000 piston hours or the one with 150piston hours and 350 turbine hours(say on the 206jr)..
flyting
Closest Airfield: LOWZ
Unread post by flyting » Sat Mar 23, 2019 8:07 pm
You'd be extremely lucky to get a turbine job with a fresh CPL.
Be in the right place at the right time with +600hrs total (all pisten) and you'll get you first chance at a turbine.
It's the Total hours that counts not how many turbine hours.
syphon
HASSELL checks
Unread post by syphon » Sat Mar 23, 2019 10:55 pm
So which would be more economical 400 hours on a helisukkel or R22?
You can have fast, good or cheap; now pick two!
CommanderKeen
Closest Airfield: Waterkloof
Unread post by CommanderKeen » Sun Mar 24, 2019 4:39 pm
I agree with your first statement but I disagree about the turbine time. Having turbine time can make a difference, as it did with my first big break. If I didn't have some turbine time already with a type rating on one of the turbine helicopter types used by the company, I would not have got the job with them. Having some turbine time will make you more employable than another pilot with the same hours but only piston time.
However, I would not use a Helicycle for these hours but rather something like a Jetranger that you may fly as a first turbine job. Of course that all depends on what the pilot doing the training can afford.
Unread post by Fransw » Sun Mar 31, 2019 10:34 am
Commander, on what turbine type did you have time? The JR?
Agree, its also about the quality hours and not only the quantity..
CommanderKeen
Unread post by CommanderKeen » Sat Apr 13, 2019 9:12 pm
My first turbine was the AS350 Squirrel, as I had an opportunity to get some hours on it at a very good rate. My first big break was flying AS350, EC130 and EC120.
Return to “Rotor Wing”
